Whats in your big bottom drawer?
BHH
I have a snap on KRSC46 and wondering what is the best way to utilize the big bottom drawer. I was hoping to see how other people have used this space.
luvit
i don't like bending over.
things i hardly ever use is put in there.
hammerdrill w/ case, heatgun, things like that.
ZRX61
Solar Blight Valley, SoCal
C clamps etc, pneumatic vac, HF *dirty* grinder that gets used to striping auto paint with those 3M pads that look like a piece of doormat on steroids.
DrkMtnDew
vendor hats/jackets, big tools, sprays/lubes, spill free funnel, manuals, lots of random stuff...
TireTracks
Yakima,Washington.
1/2" corded drill, 1/3rd sheet sander,Jigsaw,Grinder,sawzall, Assorted blades, wheels,etc. I made that drawer deep specificaly for Power tools.... Too bad my Circ saw is .25" too tall. :(
All my "engine building" tool's such as ring compressors, ridge reamers, lifter puller, ring gap filer, valve lapping paste, and tools, etc. Also my big torque wrench, timing light, vacuum and compression testers, vacuum pump for bleeding brakes and the like...
diesel research
gulf coast, TEXAS
Bunch of outdated books (old DOT regulations and 80s flat rate manuals) florescent droplight, heat gun, satellite gps tracking boxes, bunch of various diameter pipes about 2ft long, and everything that falls out of the other drawers.
Had a bunch of EMPTY blow molded cases, threw that junk in the trash can. Hate blow molded cases for most things! Space robbing hogs that just make accessing anything I use on regular basis, more difficult.
blacK20
ball joint press, assortment of light bulbs/fuses/spare parts, earmuffs, extractors, ratchet straps, bungee cords. you get the idea.
Hammer1963
Kentucky
Heavy slide hammer in metal box, Large size Tap & Die set, large PDR picks, 6" DA. Viking Mini Air file, Vise Grip slide hammer, Hood prop rod, Manual impact screwdriver.
bobemmerich
Middletown, Ct.
My corded sawzall, grinders, discs, blades. My other drawer has the compression tester kit, the serpentine belt tool,and misc. stuff I hardly use.
Black89LX
Wisconsin
Compression Gauge, Vacuum Gauge, Cylinder Leakage Tester and a Fuel Pressure Gauge... extra socket rails, my knee pad, goo gone, air tool oil, and my tool truck receipts...
WR250F
Corded drill motors/saws etc
Spare batteries/chargers
Pry bars
BFH
cheater pipes
bullfrog123
SE Idaho
Body hammers, DA sander, paint gun, cleco set, air riveter, spark plug cleaner, etc.
BHH
Thanks so far everyone!
Bullfrog123 I like the added pic! I hope others follow suit.
rayh91
SoCal
Torque Wrench, Box of Gloves, Chargers, DMM and Service Bulletins.
Surprisingly that takes up most of the space.
G1GRANDEUR
Can't remember all. ( SO compression tester, SO leak down tester, SO cooling system tester, SO torque wrenches, SO tap and die set, BP multimeter, SO ground tester, and few other things that I can't remember now) :)
TWX
Phoenix
Air stuff in one of my 26" rollaways, and the other box has weird specialty automotive tools that I don't use often, like my ring compressor.
ECP
British Columbia
Even though it's not really a drawer.... here's what's in mine;
electrical bag; sanding blocks + DA in toolbox; and my shoes.
