3/4 or 1/2 socket extensions work great as vise handles. HF extension might work.problems: bolt for handle
Did you paint it purple?
This one originally comes in red
Kythri - very nice Craftsman.....and I love the "photo booth"...LOL
SNIP
Got a old REED MFG 204R and bolted it to the fab table. No need in cleaning something like this up because it's just going to get abused. I did disassemble it and clean/re-lube everything though.
You should move the reed so the stationary jaw is past the fab bench top edge. That way material can be dropped to the floor if desired.
Ahhh didn't even think of that, even though I don't think that need has ever arisen it would be handy if needed. Looks like I'm plug welding up some holes and redrilling when I get home.![]()
Here is a Columbian vise that I need to mount to my welding table. Two man job to lift. It is stamped No. 508.
New to this board. Looking for some info on restoring a Wilton C1. Does Wilton make the name badge for the front? Any other parts available?![]()
Unless you are dead set on a smooth top, leave the extra holes, holes like that can come in handy at times...
Kythri - what did you end up doing for the nameplate prior to sandblasting ?
Apologies if you mentioned it and I missed it.
Brian L.
This seems like an appropriate place to ask with all you vise experts
My father in law has about a dozen vises manufactured from 1900's to 1940's. He asked me a while back if i knew of any way to find out if any of them might carry some value above and beyond there useful price.
Anyone know what i might be looking at here?
. Iwould guess it to weigh around 200 lb and is a columbian 508.
The 500 series Columbian vises were stationary, the 600 series is with the swivel base. That base may have been added on later. I have a new Columbian 605M3 and it goes about 80 lbs. It seems like a well built vise. Your right about the density of a Columbian vs most other old MFG's. This one is not clunky though.
LMFAO @ demoman...(snip)...My wife will be so excited when she sees her new Christmas present. I probably should wait to see what she got me![]()
The second is a Wilton I dug out of a scrap pile. I think it's a import madel, not sure if it's worth getting jaws for or not. Something I need to look into.
I picked up a Canedy Otto 2 1/2" vise about a month ago. The threaded rod is broken, but it still opens a little bit. Anyone know where I might be able to get a replacement rod/spindle? It's a neat little vise, and for $3 I could not pass it up.
It looks like it'll open about 4 feet wide, too. EBCooper, if I only had a vise of that size, I would die a happy manthe vise weighs 1,980 lbs.
I can't take any credit for this; only happened to come across the photo while browsing the web and thought it might be of some interest here. The caption seems to indicate that this person has "homemade" their own anvil and vise.
The original URL:
http://www.arboristsite.com/firewood-heating-wood-burning-equipment/128868.htm
According to the text that follows the anvil weighs 1,230 lbs. and the vice weighs 1,980 lbs., but even if the reverse is true - good grief !!!
There were no objections to the original posting so I thought it would be OK to post here.
All, recently, I finished a Morgan 10A wood working vise. My question is how do I keep the rods and other non painted parts from rusting without using die saver oil? The oil is fine for my machine vises but not a wood working vise. I've thought about clear coating but I felt that it would wear off and I would be fighting flash rust. Any solutions?
Thanks in advance!
Once in a while I wipe bare steel parts on my drill press with Evaporust. It works fine for me. When it dries out it behaves like water with sugar, leaving slightly sticky clear surface.how do I keep the rods and other non painted parts from rusting
