universal rundle adjusto-temp product no. 5025-1 toilet tank valve
faucet dfivision 3025 n. great southwest pkwy, grand prarie, tx 75050
http://www.thisoldhouse.com/toh/article/0,,218961,00.html for the how-to
article
i've supplied both my first floor and second floor toilet tanks valve with this device-----about 30 years ago! only consumable part is a 1/8 thick by 1/2 rubber faucet washer! it costs me about .25 every 5 years to maintain this valve!
AFTER I GOT THRU WITH THIS 'DOCUMENT' I DID A SEARCH........this device has been DISCONTINUED!
or this if you can purchase at GRAINGERS!
Anti Sweat Toilet Valve,1/2 In,Brass
Item # 1RLU5
Anti Sweat Toilet Valve, Size 1/2 In, Threaded 1/2 In IPS, Solder 1/2 In (5/8 InOD) or Compression 1/2 In (5/8 InOD) Connection
grainger part# 1RLU5 $27.35
i installed this in the supply line at my in-laws cottage in gaylord michigan, to
overcome the 'horrible' sweating due to the condensation problem they have as a result of a deep water well! I CAN RECOMMEND THIS FOR A TOILET, BUT CAN IT SUPPLY ENOUGH WATER/ GPM FOR WASHING A DOG?
another grainger item.............
WATTS Tempering Valve, 1/2 In
Plumbing > Valves > Tempering Valves
Tempering Valve, Hot Water Extender, Size 1/2 In, Sweat Connection, Material of Construction Bronze, Flow Rate 2 GPM, Max. Pressure 150 PSI, 120 to 160, 3 11/16, 2 1/32
Grainger Item # 4A818
Price (ea.) $60.00
Brand WATTS
Mfr. Model # 70A 1/2
NOTICE THE DIFFERENCE IN PRICE! PLUS DO YOU HAVE THE NECESSARY 'CREDENTIALS' TO PURCHASE AT GRAINGERS? THEY SELL WHOLESALE ONLY!
hope this helps!
thanx red
