warm water mixing valve for hose
PapaKlix
i'm looking to add a hose hook-up to my garage and wanted to have hot and cold water mixed at the hook-up. does anyone have any links to where i could find such a valve? all i can find is the basic hose valves.
nutjob
NE, PA
This is the model I installed last year. I purchased one of the coiled up hoses and keep it in the house by the deck. Just hook up as needed.
Can't beat warm water in the middle of the winter for cleaning the mud off the dog!
Kevin
red-ryder
universal rundle adjusto-temp product no. 5025-1 toilet tank valve
faucet dfivision 3025 n. great southwest pkwy, grand prarie, tx 75050
http://www.thisoldhouse.com/toh/article/0,,218961,00.html for the how-to
article
i've supplied both my first floor and second floor toilet tanks valve with this device-----about 30 years ago! only consumable part is a 1/8 thick by 1/2 rubber faucet washer! it costs me about .25 every 5 years to maintain this valve!
AFTER I GOT THRU WITH THIS 'DOCUMENT' I DID A SEARCH........this device has been DISCONTINUED!
or this if you can purchase at GRAINGERS!
Anti Sweat Toilet Valve,1/2 In,Brass
Item # 1RLU5
Anti Sweat Toilet Valve, Size 1/2 In, Threaded 1/2 In IPS, Solder 1/2 In (5/8 InOD) or Compression 1/2 In (5/8 InOD) Connection
grainger part# 1RLU5 $27.35
i installed this in the supply line at my in-laws cottage in gaylord michigan, to
overcome the 'horrible' sweating due to the condensation problem they have as a result of a deep water well! I CAN RECOMMEND THIS FOR A TOILET, BUT CAN IT SUPPLY ENOUGH WATER/ GPM FOR WASHING A DOG?
another grainger item.............
WATTS Tempering Valve, 1/2 In
Plumbing > Valves > Tempering Valves
Tempering Valve, Hot Water Extender, Size 1/2 In, Sweat Connection, Material of Construction Bronze, Flow Rate 2 GPM, Max. Pressure 150 PSI, 120 to 160, 3 11/16, 2 1/32
Grainger Item # 4A818
Price (ea.) $60.00
Brand WATTS
Mfr. Model # 70A 1/2
NOTICE THE DIFFERENCE IN PRICE! PLUS DO YOU HAVE THE NECESSARY 'CREDENTIALS' TO PURCHASE AT GRAINGERS? THEY SELL WHOLESALE ONLY!
hope this helps!
thanx red
Frank The Plumber
Chicago.
Why not just put in a laundry tub with a faucet and hot and cold with a porta pit that pumps it to the house? How cold will it get?
P
PapaKlix
thanks so much for all the responses, nice to finally see some options. i searched and searched with no luck.
i don't really have a use for a sink in the garage, or maybe i do but i just don't know it yet :)
the garage is in massachusetts and i want the warm water for washing my car in the winter. i did it last weekend when it was about 42 degrees and that was about my threshold with cold water.
Matt M PA
SE PA
I too wanted to do this. My current car wash water feed is only cold water...and while I could likely run a new hot water line to the garage...I've resorted to filling my bucket with warm/hot water from the basement slop sink and just rinsing with cold.
I use a pressure washer connected to a deionizing system so I don't get spots when the car dries. I still pull in the garage to wipe down, etc.
I also got a pair of gloves that are used for hunting. They look like knitted gloves, but are water proof. They're a help,too. I think they were called Ottergloves.
