yevangelis
Re: picts of your in floor heat set ups.
youre right about that ^
Butcherblock no less.
Well, I don't know if mine is set up perfectly, since there wasn't any instructions on pump speed. I may reduce the 2nd pump so the hot water stays in the pipes longer just to see the impact.
Isn't this the idea of radiant heat? To put the heat from the fluid into the floor? If I was only losing 10 degrees between the supply and return I think I'd want to slow down the flow.
What is that silver sardine can to the left of your air eliminator? Looks like a hydraulic separator but I don't see four pipes going into it.
I realize they are different (kinda the same, but no fluid exchange), but don't they both need four pipes? Must be the angle of the photo. Are you saying that is your source of your DHW in lieu of a coil in a tank? Pumps must run a lot?
Well not as simple. Handles all our heat plus domestic hot water.
Water softener >> Sediment filter >> Carbon filter >> UV Filter. Heat exchanger keeps things separate. 2 zones, top with priority.
which is more expensive to purchase and run, an electric hot water tank or an electric on demand set up? lots of good info on this site!!! building a 30x50 soon thanks
I have a question for you are you are you going to run a boiler also or just a geo thermo. are you going to heat the shop more than that?not quite sure how that works.if you could educate us that would be great. ps shop looks awsome keep up the great work![]()
Here is my simple electric setup. I was going to wait to get a new NG line ran, but found a smoking deal on a Seisco electric boiler.
Line voltage thermostat controls the pump and temp sensors in the Siesco turn itself on.
I did overlook your system Possum. I like it though a low water cut-is in order whend
the boiler is the highest point of the heating system. Again, most especially on electric
boilers and I might add, critical on DIY electric boilers.
All parts from Menard's ?...good luck with that. I design a lot of systems, but repair more. The guys at Menard's complain that the customers too often ask for help after the fact.
