rmuell01
Re: what did you do in your garage today?
Put the mufflers about 6 ft. in the air and Reduced the decibels of my compressor.
<a href="http://s178.photobucket.com/albums/w243/rmuell01/?action=view&current=IMG_0259.jpg" target="_blank"><img src="http://i178.photobucket.com/albums/w243/rmuell01/IMG_0259.jpg" border="0" alt="Photobucket"></a>
Outlander
Quebec, Canada
In the garage? How about partially in?
Addressed trailer vibration & started to make a floor lamp for my wife. Supplies for lamp = $20 or less........pocket hole jig, well a bit more :)
premierplayer
Maryland, USA
Those are the air intake filters ;) . Quited it down eh?
trbomax
starvation lake,mi.
Got some of the wall between what will be the machine shop/ office from the high bay shop framed up. My project for this week is to get it framed and the windows/doors installed.Maybe even insulated!
Its slow going because like all my other walls, its a 3 separate cavity , 7" wall with almost no thermal conection.
Lippyp
Shropshire, UK
I finally found a little time to start some work on the "new" garage, my BIL was over for christmas with his family and he helped me move some cupboards around and unload the steel shelving from the back of my truck and we set it up in its temporary home at one end of the garage, eventually its going down the other end but theres lots of work to do before that happens. Had a long discussion about raising the eaves height and the choice is currently between raising the whole roof by a couple of feet or leaving the ridge height the same and just changing the pitch on the roof and raising the side walls. Either way the roof will be coming off and will be felted, re-slated, have a couple of skylights fitted and be insulated probably this summer and the two pairs of barn doors replaced by one larger possibly bi folding doors.
Today I hope to start unpacking boxes in there and putting stuff away.
glider
Flint Michigan
Spent 2 hrs. trying to get my tires off my truck. The ***** of it is that, last time I took them off I had the same problem. Only one was stuck good. I did use a Anti seize the first time but I guess not enough. Aluminum factory rims.
JimVonBaden
Northern Virginia
I know what you mean. Same issue on my Sky:
Major rust/corrosion stuck them good:
Addred some antiseize after snading off most of the rust:
A couple months later when I removed the wheel to do the caliper paint they came off much better:
Jim :cool:
hoblick
reaplaced the volume switch on my HD Street Glide, made some trim to go around my window A/C units, put my buddies drill press together, and we started to take a look at his old bandsaw he just got.. stuff need aligned and cleaned up.
PeteMoore
N.Ireland
Spanner checked an MGB from top to bottom, gathered most of the parts to complete the car, made a cover to prevent any dust/grinding debris from sitting on the paint
Then started into restoring my folder
Pics will be in my garage thread soon
nsimps
Utah
Made a stool height bench yesterday. First project with the hand me down welder from my old man.
Jim Stabe
San Diego, Ca
I formed up a new cover piece for the cowl on my project MGB and got it fit up and tacked in place. When I widened the car I added a piece and then I tried filling in the windshield wiper holes and the defrost vent slits. All that welding on a low crown panel made for a lot of distortion so I just cut the whole piece out and made a new top on my English wheel. I was tacking it without a helmet because it takes a second or two for the shade to go clear and I can go much faster and more accurately if I just close my eyes. This is not a good practice but it is one I have done for years when fitting panels in place. The bad part this time is that I sunburned my eyelids because of the number of tacks and how close I was so I have wait a day before I can get back to finishing the welding.
Larwyn
Texas
Today I sat at my workbench in front of a small electric heater and had a few Shiner Bocks before supper. One of the neighbors stopped by and scheduled a bit mechanic work (lawn mower) for Friday morning. Met the newest neighborhood dog and watched a couple of sika deer graze under the pecan trees. Not sure what comes after death but retirement is heaven.:)
PeteMoore
N.Ireland
oh snap!!!
No sleep now due to burnt eyelids :(
Didn't help that I was attempting to weld cast iron, think brazing is the next step.
cbacres
SW Florida
Just continued to clean up and layout to my plan.
Added this cabinet to a frame with casters, attached a steel wall cabinet to the backside as I have no more wallspace and while pondering with my beer, decided to add a old drawer box to what was left of the frame sticking out.
Looks a little wierd, but I'm using up the misc. boxes I bought a while back.
Took it apart, sand blasted and primed the drawer box, will paint this WE.
Will also paint the black cabinet.
Another step closer to the next change.
trbomax
starvation lake,mi.
Still building the wall between the shops. Got the 6' ADA doors installed. Those were some heavy mo-foo's.
billcole
Northern Michigan
Well I will try this again. I built another bench for my brother. He had one already but his kids have taken it over.
e-tek
Saskatoon, SK
Finished closet-ironing baord for Mrs. E's change room. It'll get mounted on the wall and when open the board comes out with a leg that folds down to the floor.
Got the 56 Chev truck to the point where it starts with a momentary tap on the floor starter, then polished it up for delivery!
softballrz
how well do those wheels work? are they worth the investment?
trbomax
starvation lake,mi.
Had a short day today,phys theripy on tues and thurs. Did manage to frame up some more wall and get the doors shimmed and attached properly. Got a couple electric runs roughed in too.
AndysMBgarage
Mornington Peninsula Vic Australia
I installed the hardtop hoist for my SL.
This frees up space as the hardtop is held near the ceiling above the car and it can be easily fitted or removed by one person.
It's operated by a 12v electric winch that has been wired up to an old battery charger for 240v mains power. It also has a remote with a raise/lower switch so it can be controlled with one hand while the other hand guides the cradle down to the hardtop then lifts it up for storage.
Cheers
Outlander
Quebec, Canada
Yesterday, it was -20* celcius (-2* F), so my (uninsulated) garage time was limited to the bare minimum. Dragged a bunch of hand tools into the house though and finished off the floor lamp I am making for my wife.
I will show her the pictures of her dining room table covered in tools and wood bits after she says she likes it.
The insulation threads are becoming more interesting...I ignored them all summer :)
santagary
Pagosa Springs, Colorado
Worked on my new project...a 1946 ford half-ton pickup. I bought it for its' originality...cause..."they're only original once." So tempted though to tear it apart and fix/replace everything as new, but I've resisted so far. :)View attachment 159129
View attachment 159130 PS: Received my third PSA results yesterday (have to have one every 3 months for 2 years after the DaVinci prostatectomy).....0.0% undetectible. Whoopee!
036.6turbo
Yesterday I finished up the "wrap". As soon as I finish this cup of coffee, I'm going to start hanging the new vinyl siding. (late start today, I may have over done it yesterday, cold and wet, and I'm old)
Pics show an addition, we rebuilt on the rear of the shop. 6'x7' roll up doors, on each end.
JMartel
Seattle, WA
Set up my christmas present from my parents.
Also, I found a bunch of old 2x6 lumber in the woods next to my apartment, so I stole it, and I'm drying it in the garage. Going to be used to build another work bench and an outfeed table for my table saw. Gotta love free wood.
PECVD2
Albuquerque, NM
Swapped in a new pumper on my old Quincy. Now have a CHquicystien compressor.
Here is my old X2 sitting next to my new to me C-6. Still looking for original specs on this guy. I will measure the CFM out of the 3/8" port sometime tonight.
Now have this.
Anyone have an idea of what the belt deflection should be?
awdblazer
winnipeg, manitoba, canada
Now have this.
how can you measure the cfm?
JimVonBaden
Northern Virginia
Nice, great gift!
And, of course, everyone loves free wood! :lol:
Jim :cool:
PECVD2
Albuquerque, NM
AWDBlazer,
I am going to use a cheapo manual flow gauge. There are better ways with in line digital sensing guages but I do not have that type. I believe the flow gauge I have is made by Kings (not sure right now).
Calculations indicate 6.16CFM
Actual data from guage ~5SCFM with tank pressure dropped to 15psi and pump running
