metaleltr
Are there any lifts that have enough clearance to fit a trailer between the columns? The minimum distance would be 10'. Slightly less may work but I doubt it.
You need to be looking at the drive thru clearance of the lift. If your tires are no wider than 8 1/2 feet to the outside then you should be able to find a lift that will work.
The wide Bendpak 2 post XPR-10A has a drive thru clearance of 102".
Are you looking for a drive thru clearance of 10ft? I don't think there is a two post lift that has that width. The Mohawk System I doesn't have that wide of a drive thru clearance.
