Soon2AdjustYou
HF Rivet gun... huge pass!
Used it to clean up my sockets
big thanks to ryan for taking the garbage out of this thread!
EPIC fail...
the black and orange pistol-grip bar clamps.
This was the only post I could find for the 40 lb sand blaster..Does anyone else have any reviews on it? I just bought one on CL for $85, complete with 90lbs of media...Gotta pick it up tomorrow morning...
http://www.harborfreight.com/40-lb-pressurized-abrasive-blaster-34202.html
anyone try there 3" High Speed Cut-Off Tool?
used mine to cut off some sezied bolts while I was replacing endlinks on my anti-sway bar......worked pretty well.
^^ Thanks for the review rlitman, I was wondering if that set would work for Subaru's, I may need that set in the future!
Not sure if it was mentioned yet, but the inner tie rod end tool, 96558, is a PASS. That thing is pretty heavy duty. Have used it on several Subaru's with good success.
Anyone have any input on generators? Seems like it would be a risky purchase, but for the price, it is pretty tempting for backup power or camping..
I've liked this tool a lot. But I have a problem in that it's not any where near 700 ft lbs... or my air supply is massively insufficient. I've got a gauge to hook up to the impact so I can make a real determination. I'd give it a PASS regardless. It does most everything I ask it to.
I'm all for spending on Chinese tools, but not ones that will get me hurt.
My Bosch SDS drill has a clutch, and if it binds up (which I've only managed to do when drilling deeper than 12", and certainly not in 4 1/2" concrete), you won't end up with a sprained wrist. I really don't think this is one tool that's worth saving the money on.
I wanted to hear good things about this tools read on here they were OK so I went and picked one up on sale. Then I read that someone got one that was not centered so I went and checked mine, still new in the box. Sure enough a 12" bit was making a one inch circle it had so much wobble. I brought it back today for replacement. We opened and tested 8 drills, all were turning off center. An no, it wasn't the bits.
FAIL.
1000 lb folding saw horses- pass....I put a 200 lb door on them yesturday and they were nice and sturdy...I would recommend ptting some rubber on the tops, as projects will slide around without something to grab them..
Here are a few items I've gotten recently:
4-1/2" Angle Grinder
PN 95578
$10 w/ coupon
PASS
I had to adjust the safety cover as it was loose out of the box but that was no big deal. I got it specifically for a project (cutting pavers for my walkway) so all I cared about was having it last long enough to cut all the 20 some-odd pavers. They created a lot of dust so I got it as a throw-away tool after my project was done. It worked fine and I'm keeping it as a backup or if I get another dirty project. For 10 bucks it worked great and I had no issues.
26" 16-drawer top/bottom roller toolbox
PN 67831
$289 w/ coupon
PASS
Awesome box! But major warning: Open both top and bottom box while you are still at Harbor Freight! The packaging seriously *****! A lot of the reviews on their website warn about this as well. My top was dented in a bit at the bottom. It didn't affect the drawers so I didn't really care. But the bottom box was pretty awful, multiple corners dented in and paint chipping.
I took the bottom back and made them open up the replacement at the store... and the replacement was even worse! They grabbed another one, and a HUGE scratch down the side! The third and last one was fine. Pretty bad odds.
It is a great box but seriously do not leave the store without physically checking both boxes. The packaging is horrible for a 100+and 60+ lbs boxes.
Other than that fiasco, it really is a good toolbox
4-drawer tool cart
PN 95659
$99 w/ coupon
PASS
This one is pretty well known but I also got this one recently and major pass, great cart for the money. Tempted to get the 5-drawer but for my needs the black one was already probably plenty good enough.
6" digital caliper
PN 47257
$10 w/ coupon
PASS
Holds the zero pretty well, and tinkering around w/ it the readings are tight enough for what I need it for. It is identical to one I used at work at my old job (machine assembler & minor fabrication) and that one worked equally well too. As long as they don't get dirty they seem to work pretty well for basic stuff.
string level
PN 67765
$1
FAIL
I got this one just to try it out and of course major fail. Mine was not totally leveled, so if you flipped it around on the string it would give you a different reading. It also falls off the string way too easily.
24" i-beam level
PN 67783
PASS
Used for a landscaping project to verify slope, worked fine.
You're talking about the ones made of sheet metal with a wood top right? If so, indeed those are awesome. I've had a pair that i've been abusing for 2 years+ and they are still here and very useful. I wish i got a 2nd set when they were $20.
Good idea on the HF Box wish i had read this before i bought mine my fiasco was perfect top and bottom no keys for top box took 3 times to get a top box with a set of keys with it other than that very pleased with box.
I've got it. Functionally, it works fine. I turn it on and it shakes. I did wind up adding a lock washer to the lid as others have said, otherwise it'll vibrate free. From a practical standpoint, I've found a vibratory tumbler in general to be worthless. I bought the Eastwood rust-removing media, which is supposed to be fairly course. After 24+ hours in the tumbler, the hardware looks no different... just dusty. No rust comes off, hell the painted parts don't even seem to get dull. I bought some more aggressive media but haven't tried it yet. I wound up just taking everything to my wire wheel.Any input on this 5-lb vibratory tumbler?
PN 67617
It looks nearly identical to the 5 lb Eastwood unit
I only saw one reference to the HF unit in another thread but not much more than that. I've got a lot of used nuts/bolts I'd like to clean up. HF reviews seem to state as long as I add a locking style washer to the bin cover it should work well (aside from being loud).
