My paver walkway project
The Lazy Destroyer
Woodstock GA
So I've always hated using the side door to my detached outbuilding/workshop, it's just a random door that you have to walk through dirt and grass to get to. So I did a whole bunch of research and started my walkway project over the new years weekend. I didn't get crazy w/ it but I am totally new to this sort of thing so it was quite an experience.
Figured I would share some pics!
This is what I had to start with:
The area by the door and along the wall gets pretty soggy as the backyard slopes into the outbuilding. So along with a walkway I'll put in a french drain to help get some of the water out of the area and back to the undeveloped part of my backyard.
Day 2, managed to get the trench dug. I ended up about an inch deeper than I wanted, guess I got carried away with the shovel
:lol_hitti
Heidi was inspecting my work, however I think she was glad she didn't have any opposable thumbs so she didn't have to help
Also got the material delivered, no turning back now. One yard each of base material, sand, and rocks for the drain.
End of day two, put down some weed blocking sheets and some stakes. The stakes are marked about 2" and 2.5" so I have an idea how deep my base layer ends up. Also verified a little slope to make sure water gets carried away from the building and towards where the french drain will be.
Day 3 I didn't do much. I was tired so other than getting the pavers I was going to take a day off. Didn't realize my paver supplier was closed on Saturdays (oops) so I ended up just getting something at Home Depot instead. Yes, I broke the rule about not starting without having all your materials first, but everything worked out.
I had to rent the truck at Home Depot so I could get the pallet home. Obviously I didn't have a forklift so all 288 stones had to be unloaded by hand. :( How bad could it be I thought :dunno:
Pretty bad :lol_hitti but managed to get them all unloaded... eventually.
Also got material for the drain:
luvit
looking good.
you be sure to share what mistakes you made prior to correcting them, yes?
i need to learn from your mistakes, too ..lol.
T
The Lazy Destroyer
Woodstock GA
Next day I added the base material. Ended up using all of it but the thickness was good enough. I didn't rent a plate compactor so I tamped it all by hand, took forever and wore me out!
Forgot to mention the walkway is 3' wide by about 40+ ft long. Some of the pictures are a little deceiving.
Finally got to the fun part, started laying pavers down. Used some 1.25" OD PVC tube to screed the sand and started laying them down:
Took a break and also called my dad as I had to ask him some questions. Had to set up some lights so I could just work all night:
More progress:
The next day I started the real fun, I cut the end-pavers to length, I actually enjoyed this part more than everything else. My dad had mentioned he messed up one of his angle grinders cutting concrete once so I got a $10 Harbor Freight angle grinder and some masonry cutting disks, worked great!
Pounded them down by hand w/ a rubber mallet and spread some sand, done!
I still have to do the french drain but I strained a wrist muscle so I decided to do that another weekend, probably this coming weekend since I'll be in town.
I've already used the walkway a few times and it is such a nice improvement than walking thru the dirt!
T
The Lazy Destroyer
Woodstock GA
looking good.
So far, my mistakes:
Know exactly what you are going to do before starting! My walkway is a little lower than I estimated because I ended up having to go w/ Home Depot pavers, which were about an inch shorter than the other nicer ones I saw. Add to that when I accidentally dug the trench a little too deep. But it's not bad and I think I can compensate for it with extra material on top of the french drain. I broke the main rule: Dont start until you have all of your materials. Or if not... at least know when your paver supplier is going to be open and doing deliveries :lol_hitti
After all was said and done, it probably would have been easier to find a truck to borrow so I could rent a plate compactor. Only issue was I kinda needed it twice, after adding the base material and then after the pavers were done... so the rental may have gotten expensive.
If your wrist starts hurting, don't try and keep working thru it because my wrist was hurting for over a week. I think I just over-used it or used muscles I don't normally use. It feels ok now but was a bit swollen and bruised for a few days.
Verify rented truck load weight capacity. We set the over-weight alarm on the rented Home Depot truck while they were loading it. It ended up just being the guy who was helping load it that tipped it over the scale, but made me nervous the whole way home!
Also, we wrapped the heck out of the pallet of pavers and it still tipped over in the truck bed during the ride home (I was very careful while driving). No pavers ended up breaking but if I were to do it over again, if the stack of pavers is kinda wabbly... make them split it up onto two pallets so it's not too tall.
The actual process of paving went pretty straight-forward. I used a lot of helpful videos on YouTube (including the Lowes videos) and didn't have many surprises.
Also, make sure your trench is wide enough for the pavers plus the 3" or so of paver edging that you buy. Mine was a little tight but I made it work. I would probably add 5 inches to each side you need to use paver edging on, and just backfill any extra area you don't use.
larry_g
oregon
I like it. You came up with a good looking walk way there. The only thing I would change is to move it a foot or two away from the building. I had a sidewalk that was close to the house and found that I was constantly bumping or rubbing the house when moving things down the walk.
lg
no neat sig line
JimVonBaden
Northern Virginia
Great information and tips. I have a similar project coming up!
The contractor neglected to pour a sidewalk to the man-door, and I wanted to do a paver patio in any case.
Jim :cool:
T
The Lazy Destroyer
Woodstock GA
lg
no neat sig line
I think that is what I would have preferred, to either do a wider walkway or have a ft or two away from the wall. Unfortunately there were two things going against me for doing it any wider:
-There is a old tree stump about 5 ft away from the wall (you can see it in some pictures) and I wanted to have a little clearance away from that. It is pretty old so probably easy to remove completely, but wasn't sure if it would have affected the walkway as it decomposed further
-The yard starts to incline about 3 ft away from the wall near the front of the building, and pretty steeply, so if the walkway was much wider I maybe had to do some type of retaining wall. This probably wouldn't have been too hard to do but I had to limit the amount of "learning" needed for a job like this, didn't want too many variables for me to screw up :lol:
I definitely wouldn't go any more narrow, as about 3 ft seems to be comfortable but certainly wouldn't want it any tighter.
Herb
CT
"The area by the door and along the wall gets pretty soggy as the backyard slopes into the outbuilding. So along with a walkway I'll put in a french drain to help get some of the water out of the area and back to the undeveloped part of my backyard."
Ok, you have the right idea about why that area gets wet (runoff) but I think if you regrade the side hill so that the water comes down and then flows to the back of your property you won't need to install a french drain. You need to get the water away from your side walk, and it might work out better if you don't rely on a drain to absorb the water. Maybe make a small swale so that the walkway ends up being at the high point- and that would only have to be a couple of inches higher than the swale.
jasonreck71
Newnan,GA
Nice work...Hoping to do a paver walk way this year, so thanks for the list of "mistakes", hopefully I can learn from them
JimVonBaden
Northern Virginia
Can you illustrate this idea? Mine is not that much different.
Jim :cool:
-Brent-
Utah
It looks good. I'm planning on a patio this spring. After building them for other people for years, I've got some ideas I'd like to see incorporated into my own yard. One question regarding yours, did you install any paver edging? If not, I'd recommend it.
TurboBlog
East Tennessee
Great work and thank you for all of the great tips and photos, as I have a similar project on the old to do list. This gives me some more confidence than I had. :beer:
jhelrey
MN
I am a pro. landscaper.... People think it is easy to make things look perfect, etc... straight lines and so forth. It isn't at all! I've been on job sites where people give up and just pay me.
T
The Lazy Destroyer
Woodstock GA
Yup, I put down some edging on the side, they came with ~10 inch spikes. Without them I would be paranoid the pavers would start spreading apart.
If I can do it, anyone can do it :beer:
Yup I have a lot of respect for people who can do this for a living, I think the main reason mine looks halfway straight was that I had a wall for a guide. There are some videos on YouTube of paver driveway installations and man those guys work fast! I was a snail compared to that but mostly just wanted to make sure I was doing everything right
Looks beautiful. I put down 4200 pavers last spring. I appreciate what you've done.
4200 pavers :bowdown: I ended up putting down maybe 240 or so and that was it for me!
csp
Franktown, CO
Be glad you installed a straight walk. Mine has lots of curves in it and I don't care to even know how many hundreds of cuts I had to make along the edges. I don't have any pictures of the finished project with all of the landscaping done, unfortunately.
GirlnAgarage
Texas
Hey LD, nice job on the pavers.
One thing did strike me though.
You said you're installing a french drain and you didn't move the pavers away from the building because of the stump. Is the stump going to be in the way for the french drain? I'm thinking I hope your drain is going somewhere else. :confused:
T
The Lazy Destroyer
Woodstock GA
Drain is going to be beside the walkway, should be enough room, I have about a foot and a half at the moment between the edging of the pavers and the stump. But the stump is pretty composed already, only the very center of the stump is solid anymore. I'll tear out the stump but will probably not get a chance to do that until later.
GirlnAgarage
Texas
Oh good. My wrist were already starting to hurt thinking about the work you'd be doing to get it out. I've dug out too many stumps this past year without the help of my truck. No more!
Looking forward to the rest. I've got to get a french drain in our yard as well as it slopes from the street. It'll need to go in so we can get the tall retaining wall in. I've been fighting old root systems with my shovel. I don't like it one bit.
:beer:
Herb
CT
Jim :cool:
I don't have a picture here on my computer, but my house is 45 feet from the property line on one side that is almost all hill except for ten feet out from the house. The hill slopes down towards the house but I have graded the yard so that the ten foot area next to the house slopes down toward the hill, creating a small valley (swale) at the base of the hill. This area then is pitched down and towards the back yard. The heaviest rains or spring thaw have never even allowed any water to get near the foundation, and this area is never ever soggy. Maybe try this link for some pictures and a better explanation than I can provide.http://nemo.uconn.edu/tools/stormwater/swales.htm#Database
jhelrey
MN
A big mistake I see people do is use galvanized spikes to hold back the snap edging. You gotta use plain jane steel spikes.
CreekRat
Kansas
Why is that? I'm sure the big spikes I used a few years ago were galvanized, what kind of problems will this cause?
csp
Franktown, CO
You want the spikes to rust/corrode as the rust keeps them in the ground. Frost will push a smooth spike out of the ground.
Even Steven
New York
Okay, someone has to ask:
Why did you decide on making your walkway curvy like that? You could have just as easily made it a straight run, which would have been easier and less costly to construct, not to mention easier to use.
csp
Franktown, CO
Straight is boring.
I like landscaping to have some detail and something to look at, including the hardscape.
If I wanted cheap and easy it would be a plain-jane grey concrete sidewalk.
Here's a photo of the walk finished a couple of years ago. Several other projects have been done since then, but this shows the walkway completed.
AR-Trvlr
Chamblee, GA
Where did you order the sand & gravel from? Cost? I'm in Chamblee, and will be doing a similar project one of these days...
RobSmith
NSW Australia
Don't you know that after a session on the drink...that a straight path becomes un-navigational so a curvy path negates the wobbly and the walk home is safe and sound ! I've walked many curvy paths home....Thank goodness for wide 'rarely used' streets ...they could have been curvy paths !:beer:
T
The Lazy Destroyer
Woodstock GA
I got it from a nursery/landscaping company down the street from me here in Woodstock. Each yard of material (3 total) was about $25-30 bucks each. Delivery was $50 bucks. I paid an extra $10/yard to have it delivered in canvas bags. I chose the bags so that I didn't have to deal with big piles on my backyard and so that they did not have to drive a dump truck of unknown weight on my backyard & driveway.
I think the total bill was $175. Pavers & edging was an additional $350 I think for about 144 square ft worth of stuff.
csp,
That whole area turned out great! Looks awesome!
glider
Flint Michigan
Love the pavers, and a great job at that. How about sealing them? I have seen some stamped concrete work that looks wet with the gloss sealer. Over the years I have tried different sealers and never got what I was looking for. Any input on this? Here is the front of my house and no I did not do the work.
Kevin54
MEMBER EMERITUS
Urbana, Ohio
Straight is boring.
Yep, to me a straight sidewalk is boring. When we put ours in we used the sidewalk as the flowerbed edging. It does have a few straight runs but most of it is curved. I didn't use pavers but we used concrete instead.
Even Steven
New York
LOL...yeah, but it would drive me nuts to have to walk those curves every time I wasn't drunk. I'd probably just walk a straight line path, even if it meant walking on the grass. Or I'd hop over where the pavers are close to the concrete and just forget the path entirely.
volvo
PNW 45th Parallel
Kevin54...... Nice looking wide walkways.....Appears to be lightly colored cement?....The perfect contrast and look.
