Single car garage in Indianapolis
allinon72
Indianapolis
Just bought my first house here in Indy. Looked at some houses with bigger garages, but we loved this house. Only downside is that it only had a single car garage. I was willing to compromise though, I like the challenge :bounce:
This garage, as you can see in the pics, has a flat roof even, so I'll have to get real creative! I didn't get any before pictures, but the wall facing the house was finished with 1 plaster layer and 1 cement board layer, which was fun demoing. The rest of the garage was lined by the previous owner with really cheap 1x1 wooden tiles. Not sure what the heck he was thinking but it was hell removing those, along with about 200 nails.
So far I have demoed everything, ran a dedicated circuit to the garage, added 6 outlets (now 7 total), added 3 florescent light fixtures, and added a Craftsman screw drive garage door opener.
Here are my plans:
- Fix damaged concrete at the front of the garage
- Build soffit shelf at the front of the garage
- Add recessed lighting in soffit
- Insulate with R13
- Drywall
- Racedeck or similar type of flooring
I am hoping to have the drywall in and mudded by the time it really gets cold.
A
allinon72
Indianapolis
Built a shelf at the front of the garage for storage. My plan is to put some lighting underneath (recessed or pendant, haven't decided). That's where my workbench will be.
Lawson4450
somerset NJ
my mom lives in indianapolis so i am familiar with some of the houses out there this should be a cool build.
Kevin54
MEMBER EMERITUS
Urbana, Ohio
Just a word of advice and to save you some time....before you put up a shelf, toss up some insulation and either drywall or OSB and run some electrical outlets and a run of wire. That way the shelf wouldn't have to come down to do it. Indy gets cold in the winter.
LoRollinLS
i like it, its all small and cozy, lol jk. looks like it will be fun to start modifying it to your liking, i like raw garage revamps like this! good luck
Jack Olsen
Los Angeles
Nothing wrong with a small shop.
But the reason there was sheet rock along that wall was to meet fire code. Any wall that butts up against living space has to have a certain fire rating. You already have plans to replace it, so it's not a big problem. But you'll run into trouble in the meantime if an inspector sees it torn down, and (of course) you'd want it in the event that something in the garage catches fire.
Rich H.
SE Michigan
X2
Definitely replace it if it's not to your liking, but please use fire rated sheetrock to comply with local building codes on the wall facing the house.
LoRollinLS
I like how you have a small man door out the back for easy access instead of having to open the roll up door. I'm always more attracted to out of the ordinary style homes / garages that aren't cookie cutter.
onemore
long island ny
NIce I also have a 1 car shop, a mess right now, but planning on a 10x8 storage shed for all the kids and lawn stuff. Enjoy!
five0jo
I have to admire your desire for a challenge and willingness to put in the work! From what I have seen on this site, I sometimes think the smaller spaces force people to be more creative and keep their spaces cleaner. I would like to see the house that makes this worth the effort, though! :)
TurboCup87
WV
Is there room to expand? I've expanded two garages. First was to extend a 1 car into a two car inline garage. My current garage was extended to a 25'x41' deep garage with room for 4 cars and more.
If there isn't sufficient room, kudos to you for making your garage as functional as possible.
Blackbomber
Awesome - another garage like mine in size. I'm subscribing.
We small garage guys ARE forced to be more creative.
ddl2004
Vandalia, Ohio
Room to expand forward only? I'm assuming the first photo is misleading? I thought you had room to the right...
A
allinon72
Indianapolis
Haven't updated in a while, but here are some updates! Started insulating, had to do some reframing due to studs that were not 16" on center (whoever built this just eyeballed it, says my neighbor). Also found some termite damage. I also redid my fluorescent lights. I just need to finish insulating the ceiling and drywall will begin.
LoRollinLS
Love what your doing with the place man. I don't believe that you ever told us what your dimensions are. Those over head shelves REALLY come in handy.
redlinetoys
Hey! Great to finally see a garage smaller than mine!
I am in a decent size 2 car now (still too small), but my first house was a 1928 bungalow with a very small 2 car garage (as in a pair of Model A cars would just barely fit). My solution was to build a LARGE mini barn next to the garage and attach it with a small walkway through the existing side window location (maybe you could do the same in back if you don't have property on the side.)
I kept my workbench, bench grinder, vice, drill press, air compressor, roll around tool box, etc all in the mini barn and the loft was great for storage. It had a conventional 36" insulated door on the front instead of barn doors and made a great cozy fab shop and good storage for "stuff". And it was very easy to move between the two buildings while working on projects.
I am about an hour north of you with similar weather. I think you will find that after it is all insulated and drywalled, it will take very little to heat. I have found that one of those small $40 110v oil filled radiator style heaters will keep a space like this warm all winter on a very low setting (that is if you are keeping the overhead shut).
Subscribed!
A
allinon72
Indianapolis
The garage is 20x11.
Insulation is DONE as of today. Drywall will start hopefully in a couple weeks. After that, look out for some unique storage projects!
tuner4life
Indiana
Indy is a very nice city. I end up down there at least once a month. Nice project. Looks like it's coming along quite nicely!
LoRollinLS
Oh ok, so we are not much different. I run my operations in a 25 x 12. I can't wait for the new storage projects, I need some new ideas, lol. :thumbup:
Keep us updated friend. :beer:
A
allinon72
Indianapolis
Won't be doing much parking inside the garage...I drive an F150 and it won't fit. But my gf occasionally parks inside.
USMCdodge
MCBH
cant wait to see the workbench. I have a single car garage too. i just wish i had a little more space. but it is nice and easy to keep clean.
A
allinon72
Indianapolis
Made a few changes to the bench. Finally got the top on, decided to go with 3/4" MDF. Next I'll be making doors for the right side.
