Sheet Rock, OSB, ?
mvmautorossa
In addition to sheet rock and OSB -- what are other choices for wall materials over studs in the garage?
nissan_crawler
Wichita, KS
Have you checked your local building code? You may not have a choice. Many require sheetrock for fire. I've always thought about doing a melamine type sheet over the sheetrock, would be easy cleaning.
mvmautorossa
nissan crawler and PAToyota - thanks for your replys!
nissan crawler -- I am far enough out in the country that so far in our county we luckily don't yet have to worry about codes with regard to interior wall materials in barns -- this encourages one to get on with the job at hand.
And PAToyota -- many thanks for the tip to use "search" -- and for the directed link to past postings -- they were quite helpful.
rsanter
visalia ca
how about a stainless overlay on the OSB or that 'plastic' sheeting they use in some comercial bathrooms
bob
e-tek
Saskatoon, SK
I used Sheetrock (of course) with 8" of OSB for "baseboards" to guard against bumps from rollers, bikes, wheels, tool boxes. If one gets really bashed, I just unscrew it and cut another one!
ScaldedDog
Sedalia, CO/NSB, FL
I'm thinking of using OSB, with a layer of 5/8" sheetrock over it on the walls, and just sheetrock in the ceiling. I'm mostly doing this for sound insulation - to keep garage sounds in the garage - but it'll make it easier to hang stuff, too.
Any reason *not* to do this?
Mark
MXRACER
Wisconsin
Mark
Only one I can think of is $$$$$
