L5wolvesf
I am considering putting in a pad outside my garage door to extend the smooth automotive working space I have available. It would be 9 ft wide (width of the garage door opening) by 12 ft long (if county does not nix that for set back from the road). My questions are, what do I need to make it a solid pad? What specs on the concrete, or should I go with asphalt? Cost is an concern and is part of what I am trying to figure out. How much of a cost difference is there between concrete and asphalt, generally speaking? How deep should it be? Does it have to have rebar, and if yes how much? The garage floor inside is concrete. There is probably more but that’s all I can think of right now.
Thank you,
Larry
Thank you,
Larry
