air tool oil
MD11
USA
I just use this stuff from CH or something... I have a huge bottle and it's barely even 10% gone.
rlitman
Long Island
I use whatever cheap air tool oil I happen to have.
ATF is probably very good, but it sure smells awful.
tbobbo
Bismarck, ND
Marvel air tool oil, and deep creep once in awhile for cleaning. I oil my tools after EVERY job I use them on. The other guys at work hate that my tools spray them with oil whenever they borrow them. Then I ask them why they are using mine.............."uh mine quit working" is the usual response. Hmmmmmmmm I wonder why.
VinDSL
Arizona Uplands
I dunno...
At work I use some sort of Ingersoll Rand air oil. The "company" bought a **** load of it, and it's lasting forever. Heh! It's free, you know?!?!? :D
At home, I just use WD-40, chain n' cable lube, or whatever I find that has a straw.
Never thought about using Marvel Mystery Oil -- glad I read this thread!
I *think* I'll give that a whirl... works in everything else, so why not? ;)
redwrench60
East Tennessee
ATF will swell or rott some types of rubber. The o-rings and lip seals in automatic transmissions are of a special type of rubber made to be compatable with ATF. It might be a crapshoot on the seals and gaskets in your air tools. I've heard of people doing this but Air tool oil is cheap.......repair parts aint'.
LSU
I've got a plastic bottle of Senco air tool oil. I've had it for years and years. When it runs out, I'll buy another bottle. Seems to keep my tools running fine.
fm2176
Down South
I've had the same bottles for years: Snap-On, CH, and a couple of bottles of some other brand. Maybe it's time to consolidate them into one bottle...
I oil mine liberally before use. The tools that don't get used much, like the air hammers and riveter, get a good oiling every year or so.
G
GoBlue
Under a car...swearing
I should add that i have used ATF for years and have never worn out a pneumatic or had any other problems. I picked up a re-branded Aircat yesterday and i had asked if it was a sealed unit/oil bath or if i had to grease it. He confirmed that it was an oil bath unit and to oil the inlet with ATF once a day. Unbeknown to him i already used ATF as oil about %90 of the time.
DHS
Central FL
My dad used ATF since he started turning wrenches and never had a problem. I mix alittle MMO with ATF and use that. Only because the cheap HF framing nailer I have will stick if you only use ATF.
belu0501
As a tool dealer, I was told that you should use a good air tool oil ( I sell marvel) and oil all your tools at the end of the day, plug them in and give them a quick squeeze to distribute the oil in the tool, and then let it sit overnight. That allows the oil to lubricate and clean. I know that PB makes an air tool cleaner that I have had good luck with. But I tell most of my customers to run a little ATF through a couple times a month. Thats just my 2 cents.
-Luke
VinDSL
Arizona Uplands
How much oil do you guys use?!?!?
I oil my tools 'til smoke (oil mist) is blowinging out the exhaust, when I pull the trigger. LoL!
Doesn't seem to hurt anything... but, I don't know if it's helping things either.
Jawn
Stuck in traffic, GA
I put 2-3 drops in each time I get 'em out of the toolbox (or before I put 'em away, if I forgot before I started).
adcrawfo
-Luke
We've started using the PB stuff in our air grinders at work and have had excellent luck with them lasting longer. They grind 8 hours a day and oil them before the start of the shift and after break.
Sent from my Milestone X2 using Tapatalk
