Show Your Tools Working.
Diesel_Crawler
Canada, NB
I see lots of threads showing off tools around here, which are cool. But I want to see what neat places they go and what they work on. I will start.
I had a customer call me asking of there was anything I could do in a hurry with a hydraulic cylinder that would not go in or out "For some reason" and that he would bring it in once he got it off the machine. No problem I figure a quick packing job and off he goes.
This is what he brings me...
Now where the tools come in, Love taps and a pin wrench just was not doing it. So I used my big red wrench :willy_nil
Once I had it out, you can see how bad it was even in the gland, which needed a big love tap to come off.
So lets see come pictures of YOUR tools earning there keep! :beer:
plewlandsbob
Elgin , Scotland
As an agricultural engineer, I , quite often see cylinders in a similar shape. We usually get the local machine shop to make new rods for us. I like your stand for holding the cylinders. Will have to fab up something similar. We use a big vice to hold them or try and slacken the nut when it is still on the machine.
msnow
That thing is pretty awesome what he was able to do to that rod.
metalhead212121
Diesel_Crawler- what type of shop do you work in??? It looks like some sort of metal fab shop. Sorry to hear that your ex-wife stole a lot of your tools... :mad:
Rico.
England
Sadly as a DIY'er I can't work and take pictures at the same time. The closest
thing I can offer is a pic of my right angle air die grinder I was using to clean
up the head of my dear Supra before I completely disassembled it. :thumbup:
Good thread by the way.....
Bikes&Bowties
Washington
When I help out in town I don't use my tools. A long with some other people's shops.
So at my shop this JD 4010 is the current project, ****** overhaul is why it is split.
This took me about 80 hours suburban to crewcab. I also built the trailer you see the Burbank on
This has been a long term driving project. Going to go through it's last stage this spring.
This was a fairly fun one. About 120 hours into it. I dont like height and color choice though. But it's not mine.
D
Diesel_Crawler
Canada, NB
I run a machine shop right now, I have 5 lathes 2 mills 2 drill machines 2 presses and the hydraulic service table. I do a little of everything truck and trailer, heavy equipment, auto, marine, aviation, farm. Its a super job.
Yeah I have learned my lesson with women, go to bar then take her home to her place give fake name go to different bar next week. its easier that way.
If you want I can grab some pictures of it, it has a 4000psi pump on it for testing and we have a 50 gal tank we can hook up to it to check large systems as well as power up implements off machines. The best part is that it has side mounted cylinders so we can hook up the home made wrenchs and turn of rod nuts. any fluid left can run out and is caught in a catch system so no mess.
Do you run a service truck or are you a in house guy? What do you dislike working on the most? Mine would be manure spreaders...they never break down when there empty or on a day when there is no breeze. :lol_hitti
Heavy Metal Doctor
Mason Dixon Line
DIY or PRO, either way it's hard to show the tools working....and most of the stuff I take pictures of for whatever reason, they are usually focused on the work, not so much the tools it takes to do it.....But I scanned through my work pics and came up with some:
3foot pry bar helping me install a Transfluid coupler on a big old Detroit:
Drilling truck frames - love this thing - it'll punch a big hole through in seconds:
Finished...oh, and mount tab welded to the truck body, too....
Damaged blower inlet from an exploding fan wheel. Don't see the tools much here - Miller mig and Plasma machines
Cut the cone out with the plasma:
New rolled cone to weld in.
Finished and ready to go back on the machine - saved the customer about $1000 by repairing it rather than buying whole cover ready to bolt on.
Sweeper stripped down for some major repairs - put the hydraulic lines / manifolds in "traction" from the ceiling to avoid disconnecting everything:
Going back together - assorted tools all over - 1/2 & 3/8 impacts guns, air drill, sockets and wrenches laying all over the subframe:
Trailer came in the shop like this:
Work in progress - takes a little bit of everything for a job like this - how many tools can you spot here??:
Pulled out like this:
geologist
I could tell you some stories about working with Oklahoma's Geological Survey. Most of them involve copious amounts of alcohol in friendly one-horse towns.
Outside of the "Welcome Center" in Sulphur, Oklahoma
D
Diesel_Crawler
Canada, NB
ok ok I know its hard to get pictures of your tools working, so how about things you work on with your tools around or laying on it. :D
Welderguy24
Alexandria, MN
Although I work in a heavy truck shop, the owner of our shop also owns a small trucking company which hauls gravel and feed in end dump trailers. This is what happens when half a load of distiller grains freezes in the trailer and you try and dump it next to a parked JD 4440. Needles to say it was way cheaper to buy a used cab and have me switch it over than to report to insurance.
In the second pic you can see my 36" SO pry bar against the tire.
D
Diesel_Crawler
Canada, NB
Any pictures of the muched cab?
jdcompman
South Dakota
Great tread! I'll have to remember to takes some snaps when I'm working on my next project. Just a DIYer here.
Great work guys!
Welderguy24
Alexandria, MN
Slow day at work, figured I could grab some pics. Here is some more of the cab. It is sitting crooked on the floor but this is how bad it was leaning on the tractor as well.
And here are some of my tools at work. First couple are working on the tractor using my home box as a cart until I take it home.
Here is a shot of my tools working on a brake shoe/s-cam/cam bushing/slack adjuster/wheel seal replacement
sdguy55
Pierre, SD
What i did today...first time ive pulled a ******
sdguy55
Pierre, SD
I am so jealous of your lift
Not gonna lie. It is pretty sweet. When i first saw someone roll them under a truck to lift it i literally, out loud, scoffed. And then it lifted it no problems. And then they wanted me to get under it! Took me a lil while to get used to it.
Heavy Metal Doctor
Mason Dixon Line
Some day We might get another pair, but for now I can only lift up one end.....but we don't do chassis work - getting access underneath is usually just to run a hydraulic hose or get to wiring.....
16k lb rated
SMKS
USA, planet Earth
I'm just a DIY'er. My tools have been getting a lot of use on my girlfriend's Beetle recently. I replaced the rear axle bushings, front strut mounts and control arm bushings. Unfortunately, there's still plenty of suspension clunks.
Scottsdale10
I didn't know you were on here it's squareforceone from 67-72chevytrucks and as you can see from my user name i like squares :3gears:
sdguy55
Pierre, SD
3406 E turbo. 9/16 variations of ratchet, ratchet wrench, and wrench.
ssblood
Nice pics. Fleet work seems so boring seeing some of the stuff you all do. Will try to snap some pics tomorrow.
jeffmoss26
Cleveland, Ohio
Nothing too fancy, just toning out some data cabling for a customer.
Notice the red Snap-on flathead! I replaced a Klein 1/4 inch with that and the difference is like night and day!
Welderguy24
Alexandria, MN
Think that's bad, should have snapped some pics of the Acerts I just worked on recently, oil cooler on a C13 and a water pump / overhead on a C15 in a Pete 387, talk about cramped f%#kin quarters!!
