Show Your Tools Working.
Matt472
Alabama
Those socket trays, where can I find them?
darkzero
SoCal
I got them 8-9 years ago when I was an auto mechanic. I had an old catalog & gave my SO dealer the p/ns I wanted. He was only able to get certain ones in certain colors as he said they were discontinued.
They were made in red, green, & orange. I have the 1/4 & 3/8 short metric in green & 3/8 deep in orange (still looking for a green). They're magnetic lined in the center & the back plates are removable so you can stick them to the side of the tool box or so it doesn't move around in a drawer or on the service cart.
Although they've been discontinued many years ago they still pop up on ebay. Search Snap On Magnetic Organizer
sdguy55
Pierre, SD
Think that's bad, should have snapped some pics of the Acerts I just worked on recently, oil cooler on a C13 and a water pump / overhead on a C15 in a Pete 387, talk about cramped f%#kin quarters!!
We have a guy rebuilding a c15 and i was looking the motor over yesterday and its kinda crazy the similarities between it and a 3406e (transfer pump on front, fuel line in back) etc
sdguy55
Pierre, SD
Well i got to do a waterpump on a c15 acert yesterday...it wasnt horrible i thought just alot of trying to figure out what the hell has to come off and what doesnt.
Skin
Boston
I like this thread so heres my small contribution. I muck about in small engine stuff part time, so heres in our small shop. Doing a pretty basic axle bushing R&R on a mid-late 70s Ariens. Some of these can be giant pains in the asses but this one fell apart with ease. Testament to the quality of the day. Newer machines the hubs rust to the axles in a couple years. Dont even get me started on the big box store brands with plastic liners that swell under the hub. Anyway the worse of the two is actually from the opposite side i did before i snapped a few pics. Almost into the flange. Impacts, torches, and hammers are your friend with all the rust but one must be very careful tightening. I prefer my 1/4" ratchet. Either the studs are so small they break right off or the cast aluminum parts shatter. Doesnt take much force at all. Although it wasnt in for any engine work did an oil change on it anyway. Needed it too since it was down about 10 ounces from the original 20.
Monte
Germany
removed the bumpers with the help of 2 jacks:
rat. screwdriver in action
removing engine...
cutting sheet metal
misc.
oil filter exchange
making batterie frames for a electric car:
removing engine bearings on a small block
valve removal
transporting a rear axle
removing 4100 engine
plasma cutting
sanding a hood
more sanding (bench grinder stand)
removing exhaust bolt
Skin
Boston
Skin, that is an interesting Craftsman ratchet...never seen one like that!
If I am seeing that correctly, that is one of craftsmans newer 84 tooth ratchet. They have em in sears near me for about $65. They dont feel like 84 tooth just by turning them by hand, but I have not used one in the field yet.
Correct, 84T 1/4". That drive size has been on sale for $35 for quite awhile now so not entirely unaffordable. I have the 3/8" too. Not quite as smooth as a dual 80 but they are thinner and a darn nice ratchet none the less. I put some good use on both since i got them about a year and a half ago. Even got another set for home :).
mrbreezeet1
Moundsville, WV, 15 miles South Of Wheeling WV
Some day We might get another pair, but for now I can only lift up one end.....but we don't do chassis work - getting access underneath is usually just to run a hydraulic hose or get to wiring.....
16k lb rated
Thats pretty wild, think I saw a picture of those things lifting a bus up.
So what do you do, just roll one under each wheel and lift it?
Do you need 4 people to raise it, of are the lifts tied together?
sdguy55
Pierre, SD
What i worked on today. Payloader that the engine and ****** have to come out...not alot of fun.
Elroy
kentucky
Case spread? Interesting never heard that before...what exactly does that measure?
It's a physical measurement that is an indication of the preload on the carrier bearings
On a 9 inch Ford, Henry specifies .008 to .012 case spread with new carrier bearings and .005 to .008 with the original bearings. This spread is obtained using the right hand bearing nut (opposite ring gear) starting from zero back lash. Once the case spread is introduced the carrier bearings are properly preloaded and if all the other parts are right you'll have the correct back lash.
This Nodular Iron 31 spline Detroit locker with 3.70 Richmond's came out spot on.
Drive side
Coast
straightup
Nevada
This thread doesn't specify auto/mechanic only photos. But that's all it has. I thought I'd offer something different.
This is what I was working on today. I've got a mix of Klein, Ideal, Knipex, Milwaukee, Fluke, Lenox, and Sargent tools in the photo.
The weather has been great for working outside!
bigsteve1969
i agree on the oil cooler on a c13 but have you done a waterpump on a sdp cat? talk about a pain
sdguy55
Pierre, SD
Engine and ****** out of payloader
chumley360
Well I don't have a lot of pics while I'm working but I do have one I like and a goofy video of my best tool.
Tool at work
Altec
SoCo, MD
I actually broke it loose with a wrench first. But it worked like a charm
Ah, I was mainly wondering about breaking it loose. I don't work on much hydro stuff, but there is a masonry chisel in the box for it! Easiest way I know to break large loses loose.
Welderguy24
Alexandria, MN
One of our own trucks spun the #4 rod bearing in a C13 Acert. This is a 4 axle truck which pulls a 3 axle live bottom permitted to 108,000 lbs. Lets just say the small block and 10 speed combo was less than desirable. So out with the C13 and in with a 6TS 3406E big block and a 13 speed ******.
This is right after I pulled the motor with my new cart at my side.
EDIT: BTW the truck is a '06 KW T800B
chumley360
Well it's the setup before they go to work. It's tough pulling the torque wrench and snapping a picture alone. I'm torquing the 5th gear nut on a NV4500.
Harwinton
You know...I think I might have that exact same snow thrower! Got a good shot of yours from the top or side?
CoSnipe
Wheat Ridge, Colorado
Took it apart:
Put it back together 15 miles away 2 days later:
My truck is my biggest tool and hauls all my **** around.
From last year, 2 trucks to pull a V12 out of a 657E:
Exploded retarder as a result of bad motor mounts in a 627G CEX last month:
Monte
Germany
Monte,
This isn't an S10 pickup, is it? The whole front suspension looks identical to my Chevrolet S10.
it was a 90´s Buick Roadmaster station wagon. But you´re right the suspension is very similar.
