Knipex vs NWS?
bcradio
New Mexico
Yup i started it. School me on the pros/cons of each. Which one makes better of a certain type of pliers vs the other?
Fyi: i own about ten pair of knipex and no NWS so i want to learn.
Thanks
Moose-LandTran
The Brink of Insanity (England)
Started what? :headscrat
I have both, more NWS than Knipex, because i think they're better. Knipex Cobras are very good, as are their pliers wrenches. But for general purpose pliers NWS are far better. NWS side cutters are the best out there, by far. I just bought a pair of their wire strippers the other day and they're really good, much better than anything else i've used.
The fit and finish of NWS is far better than Knipex.
RKA
I've got a small set of NWS mini electrical cutters and I would not recommend them. Qualitywise they are on par with craftsman professionals. They just aren't machined very well. I'll stick with the swiss stuff there. I've also got some regular NWS side cutters and end nippers which are both quite nice. I've purchased water pump pliers, pliers wrenches, various styles of needlenose and probably a few others from Knipex and really like all of them. Generally speaking, the Knipex stuff just seems to feel a little better, but we're spliting hairs I think. Both are far and above the sears stuff I've used in the past.
Trucky
They're both at the higher end of pliers for sure. Either one will do you just fine. Picking out the small differences between the two is just being picky I think. Not really much concern to me, really. But I'd still like to see exactly what the differences are.. they appear to be pretty darn close from over here.
DrkMtnDew
I have a couple of both and i think both are awesome. NWS has flashier designs though.
Trucky
For us US-based folk, Lowes sells Knipex and so does Sears, so it's cheaper to buy Knipex sometimes because of no shipping charges. They're pretty close in price... aka pretty high but they bring quality stuff to the table so i guess they can charge whatever.
Danglerb
SoCal
When you start comparing Knipex and NWS your hooked, and hooked deep, just buy some you know you will eventually. Maybe start with the Fantastico cutters?
Goldhawg
Depends on which part of the planet you are located on.
Since you list no location, I cannot help since prices vary from continent to continet and supplier to supplier.
I was interested in online sources for either shipping in CONUS.
Skin
Boston
http://german-hand-tools.com/nws-pliers.html for NWS. Prices seem on par with Knipex.
For Knipex buying online check Amazon and, believe it or not, Sears.com. Both sites list most of the Knipex catalog. Sears can actually have some pretty good prices during their sitewide sales.
Cant add anything as to what is better since i couldnt sway myself to spend the premium. My Craftsman/Snap-On pliers serve me well enough.
gustsant
Denver, CO
I have a few pairs of each and honestly I cannot say which is better but I can give some pros and cons.
Knipex :
Pros
* Handles are easier to clean
* Movement is smoother
* Plating is better and looks more resistant
Cons
* Machining is horrible, razor sharp edges (in the body, not the cutting edge)
* Price
NWS :
Pros
* Handles fit and feel are excellent
* Machining is excellent
* Great design and ergonomics
Cons
* Plating has flaws (chrome version)
* Movement is restricted in some models (plastic handles are too long and get in the way when closing pliers)
Hope this helps.
jflores
All of my pliers are NWS and I recently purchased the Knipex pliers wrench and the Raptor. Overall, I think the quality of the NWS are better, but they don't make anything comparable to the pliers wrench, so I have both on my board. I've toyed with getting a set of Cobras, but the NWS Quattro have served me well and I can't see spending on another set of waterpump pliers.
I like my strategy obviously, I have mostly NWS, got the best plier Knipex makes (pliers wrench), and I have Channellock Nutbusters for when something just won't come off.
ricleh
Sacramento, CA
NWS does make a model that is very similar to the Knipex plier wrench. NWS calls them PowerMax fittings pliers. They are model #'s 166K-42-250 and 166K-49-250.
jflores
ricleh -
I have those. They are nice pliers and good for not marking fittings, but they lack the self ratcheting action. At least, i haven't been able to do it quite as well on the NWS as the Knipex, its a different geometry.
Steve_P
I have NWS, Knipex, channellock.... All have their good points. Knipex plier wrench and Cobra are better than NWS offerings IMO. OTOH, for everything else, I like NWS over Knipex. NWS Fantastico is the most awesome cutter ever :). For general pliers- needle nose, side cutter, etc, NWS seems to have better machining, fit and finish than both Knipex and Channellock. If you look at the bent tip needlenose, the NWS jaws meet absolutely perfectly, Knipex does not, Channellock is not even close. Knipex wins on selection.
jflores
I figured this thread could use a couple photos. As you can tell I'm an NWS fan, although Knipex is a very good tool.
jflores
No they are not. I've been wavering on spending some bucks picking up the Cobras, just to compare, but I'm not a pro, so these tools work way better than I do :)
er1c
New York, USA
Steve_P, you wrote that your Channellock bent tip needle nose pliers don't line up anywhere "even close." I just purchased a set of Channellock #386 5 1/2" bent tip needle nose pliers, and they line up perfectly. Which model do you have?
John316
Anywhere, USA
I wonder the same thing. Knipex and NWS are better than Channellock. I own some of all 3, but I have a lot of Channellock and the jaws ALWAYS have great alignment. I have had different defects sometimes like stiff joints (on the pliers, lol), poor finishing on the outer edges, but never misaligned jaws.
bcradio
New Mexico
sorry guys, busy yesterday. Here is my modest Knipex collection (sorry for bad picture). I will try and get a better one. Great discussion thx for input.
bcradio
New Mexico
I guess the main question I am asking is if say NWS has better diagonal cutters where Knipex might have better cobra style pliers.
Who prefers what tool from what brand? Or specialty must have pliers like the raptors?
bcradio
New Mexico
Ok the Fantasticos have been added to the list. Which is the best model?
gustsant
Denver, CO
rj-oz
Western Australia (South West)
I have just received my collection of NWS pliers cutters etc, I have issues which I will not discuss or show yet, as I'm still corresponding with the supplier, but will shortly, if someone could post a pic of their Fantastico's fully opened, front and rear it would be appreciated and very helpful.
Plasmatic
Hope the issue gets resolved fast -- great product from both companies. Love my Fantasticos.
Steve_P
re NWS plating, their chrome finish is not much plating; Knipex's chrome plating has a much better finish. NWS plating is very minimal. On my Fantasticos with chrome finish, when you open the pliers, you see only nickel on the hidden areas when they're closed. This may be with rj oz alludes to.
re my channellock bent tip needlenose comments, I don't know the model, they probably only have one, but look at Monte's pic on NWS- the channellock faces in my pliers do not align like those NWS- which mine duplicate
