Recommendations for electronic air filter?
YNOT2K
Lynnwood, WA
can anyone give recommendations for a whole house electronic air cleaner? the kind that goes in the cold air return ducting.
also looking for best price, so any recommendations for where to buy would be appreciated too.
any tricks to installing it myself?
thanks.
theoldwizard1
SE MI
This is a "be careful what you ask for, you just might get it !"
Electronic air filters require frequent cleaning, like once a month, for them to be effective. Best way to clean them (used to be) in a dishwasher,
Dan in Pasadena
Pasadena, CA
...Electronic air filters require frequent cleaning, like once a month, for them to be effective. Best way to clean them (used to be) in a dishwasher,
We literally JUST had the entire HVAC system in our house replaced. Finished last Friday. This included having all the asbestos wrapped ducting removed/replaced. We went with a Goodman system. Looked at Trane and others but the Goodman has a lifetime warranty on a stainless firebox - our old, cracked one was the reason we had to make the investment now, and also the fact that the A/C unit had died last summer.
Our contractor and the literature told us we only need to put the filters into the dishwasher about every 6 months. Don't know if that would be different in other less dry parts of the country compared to SoCal.
K'ledgeBldr
Johns Creek, GA
Insight scale:
HANDY-----/-----/-----/-----/-----/-----/-----/--$--/-----/-----Professional
Somewhere in there-
Sheet metal work (rebuild the plenum), electrical work (need dedicated 15amp circuit), General HVAC knowledge.
Y
YNOT2K
Lynnwood, WA
Insight scale:
Somewhere in there-
yikes! i thought it would just wire into the furnace's supply panel, like a thermostat. rethinking this now....
HVAC Phil
Akron, Ohio
If you have a newer furnace, there will be EAC terminals for the power to the air cleaner. You don't need a seperate circuit for it.
Y
YNOT2K
Lynnwood, WA
here is what i have to work with - the sheet metal seems to be already in place for a quick install. let me know what you all think.
csp
Franktown, CO
Is that the return or supply duct?
I prefer the 3"-5" thick, low pressure drop filters like the Air Bear vs. electronic.
Y
YNOT2K
Lynnwood, WA
just checked out the Air Bear online and they look good. thanks for the advise. i may end up going that route.
