Nutdriver that fits on 1/4" Ratchet
Neodogg
help the ignorant, why would you need the 1/4 drive in the back? Why wouldn't you just use an extension instead of this?
Chrislols
I have an oldschool MAC red handled version of this from the 60's/70's from when my grandfather was alive.
It's still in perfect condition, although I don't use it to preserve it.
Neodogg
Yep, turn it by hand with just the handle, then finish it up with the ratchet. Real handy once you try one.
hmm, interesting I gather using the ratchet would give you more torque.
I see Grainger has a Proto one for $7.35 or a Blackhawk on clearance for $6.37. choices!
Alchymist
Central PA
Couple of pics of the ones I have - the Sk has a solid shank all the way through, probably a handle molded around a 1/4" extension. The Easco has what looks like a pot metal recess molded into the handle - note the cracks in the corners.
Gtamazing
Fort Erie On.
http://www.ebay.com/itm/280474764409?_trksid=p5197.c0.m619
USA Williams
Alchymist
Central PA
Here's a variation I find useful at times, wish I had the Phillips version also.
ishiboo
Oshkosh, WI
Old post, but Cripe also has a Kobalt Made in USA spinner for $2.50, or a Craftsman for $4.50. I have a couple of the Kobalt's and they are fine.
RCStocker
Indiana, California, Australia
It seems like every swap meet and junk store has one for a buck. I picked up 2 SK ones last week for a dollar each.
The Stahalwillie ones are fantastic, the have the driving square in the handle. That would be very handy.
losabio
I bought the green handled extendable harbor freight version. I cant find a link to it, maybe someone can provide it. Cheap, great quality for the price and a nice handle feel.
I have this one and have used it more than I would have expected to. I like the weight and shape of the handle quite a lot.
03protege
Louisiana
Wow I ordered the Kobalt one a few weeks ago and didn't even realize it has the drive on the back. Just went and checked and it was there.
Unfortunately it appears to be exactly like that broken EASCo model shown above.
metaleltr
Western Ohio
Older craftsman drive handles are made like that Easco, but the newer ones have and extension through the entire length.
mvptrukin
Denver, CO
theoldwizard1
SE MI
KEH
They are nice to have and are found in different levels of quality. Advantage over nutdrivers: you can use ordinary 1/4 drive sockets. if it has the female drive in the top you can use your ratchet for more leverage.
Advantage of nut drivers: the nut driver has a hollow handle and if you are running a nut on a long screw you can run the nut all the way down, usually, because the screw can run up into the hollow shaft.
Helped a friend who started a starter-alternator rebuild business. He settled on using the nut drivers for above reason. Unfortunately, his employees had a tendency to use pliers to hold on to the nut driver handle to get extra leverage, with the expected result of making the handle rough.
KEH
