Could use help finding brake rebuild part
mad57
wagner lockheed fe-20936 Could use help finding brake rebuild part listed, the master is in a 58 plymouth savoy, i was about to find rebuilds kits for it but the kit bore is larger than the master ive got, a google search showed an old ebay auction said ford master. I also need the boot that bolts to back side to help hold the cyclinder in, any help would be great thks.
nutjob
NE, PA
If you need the master cylinder rebuilt or sleeved check out White Post Restorations.
http://www.whitepost.com
I am getting a weird error on the web site. Its been 22+ years since I had a master done here but I think they are still around.
Kevin
9c1nova
Just checked that site, White Post Restorations, White Post, VA (540)837-1140,
Ask for "W.R."
Hope this helps.:thumbup:
DIC
This guy don't have a web site. But I bet he has the part you need.
Here is a YouTube video of his place.
phone # 817-275-2381
KANSASBOY
Have you check ROCKAUTO.COM OR NAPA.COM Both show repair kit for 58-59 Savoy
mad57
Problem seems to be that the master i have is not original to the car, i have bought rebuilds and when i got them realized that they were not matching my master, so i gathered that 2 diffrent companys didnt mess up, for close to 100 bucks i can buy an original one used off egay, but really thought that given this one i have has a part # i would be able to rebuild it. I will try calling the places mentioned above again thks.mad57.
mtnkrake
That casting number crosses to 5 master cylinders from mid 60's Chryslers. I'm assuming its a manual cylinder. A Wagner # for the kit is F106472. 1" bore.
CARQUEST # is m1246
NAPA # is 256
Raybestos is mk256
I show the boot in my kit (CARQUEST) but not the plate that bolts to the back of the cylinder.
Hope this helps.
mad57
CARQUEST # is m1246
NAPA # is 256
Raybestos is mk256
Hope this helps.
Thanks ill start with those too, thanks again.
