Can You Replace 20amp Breaker with 30amp?
DonIvey
I have a Maxjax that requires 30amp breaker. My garage is fairly new, but has 20amp breakers for wall outlets. Can I just replace one with a 30amp breaker to use for the Maxjax? Thanks,
Don Ivey
Smithfield, NC
bww_mnm
Chicago area
Don Ivey
Smithfield, NC
No. Your wiring won't handle 30a. Potential fire hazzard.
djd99
Owosso,Michigan
Everybody will say no because code says you have the have #10 wire for a 30 Amp breaker. I will say this I've been doing it for my air compressor and don't have any issues it's just not code.
I still won't recommend it for that reason but I will continue to do it as I cant rerun a #10 wire. My compressor will not run on a 20 amp circuit without tripping the breaker on startup so I threw in a 30 and haven't had a problem since. Don
plinker
Northern Wi
For code, you will need to run 10ga or bigger wiring for the 30A breaker.
I would run 8ga wire myself.
I dont know how many amps a lift pull's, but your compressor wont likely overload the circut as bad, I think.
dirttracker18
Slate River, ON
Very different for a compressor that sees a spike in amps when it turns on then likely levels out at something much lower. If your compressor is suppose to run on 20 amps (does it have a 20 amp plug on it? Rating on compressor?) and trips the breaker you have a problem and should get it fixed.
A heater on the other hand will see a continious pull of higher amps. Code is there to protect you not to be some kind of a hassel. Do it right and sleep well at night.
Simple answer is no, you are asking for a fire in your wall.
Run an external line (correctly sized and shielded if not in conduit) out of your panel to an new appropriate outlet directly below. Short and sweet and within code.
Perhaps an electrician can chime in here (or place this in electrical as well) and let us know if you can run it right next to your panel and how short it can be.
D
DonIvey
Thanks for all the replys. I think the external line in conduit will suffice, and I'll feel safer when using it. Thanks again,
Don
1948
IL WI border
ever look at how a lightbulb works? imagine that as your wires in your wall....... covered with a nice melt-able plastic.....
FreddiFiche
Minnesnowta
It's your garage.....but something to consider;
If you do have a fire (we all hope not!), whether this is the cause or not, your just setting yourself up for a fight with the insurance company. They are very good at the miss-direct, delay, 'find any reason to delay/reduce the payout.' If they bring in a fire investigator, one of the first things they do is run down the breakers, looking at sizing and wire tied to it. (And this doesn't have to be a 'total loss' fire either....)
Not trying to be preachy, just really don't want you to end up on the short end of the stick if something bad does happen. Any way to add a new run? (Even surface mount?)
Good luck.
Freddi
cw_racefan
Don Ivey
Smithfield, NC
On top of what everyone else has said, I questioned this when I first got my MaxJax, because they were inconsistent with what they said for ratings. Mine was an early one, so they may have changed, but the unit itself does not have a 30 amp plug on it. I called them and they said a 20 amp circuit would be fine. Been using mine for three years now and never had an issue on a 20 amp circuit (dedicated circuit).
Craig
djd99
Owosso,Michigan
I have a 5hp farm duty that needs around 30 amps on startup
Don
Probably they best solution is to run a new line.
Good luck.
Freddi
thanks freddi but Id be screwed anyway as my garage is not insured......:shocking:
Viriiguy
Knoxville Tennessee
Are you supposed to? no. However in my current rental.. The dryer was on a 20 amp breaker. It kept kicking it. two years ago I yanked it and put a 30 amp in it.
Never had an issue since.. And I have checked, the wires are not hot under load.
With that said... YMMV. Fishing a new wire is not that hard.
nmk_61802
Central IL
Craig
I'll add this:
http://www.garagejournal.com/forum/showthread.php?t=37717&highlight=maxjax+breaker
mikeyr
Santa Barbara, CA
I run my MaxJax on a 20amp circuit, not popped the breaker yet.
I would not change the breaker without changing the wires but I would try your MaxJax on the 20 and I bet it works, just like mine.
MoonRise
Can you? Sure.
Should you? Different question and the answer is "It depends".
But in general the answer is "No, do not go and put a 30 amp breaker in place of a 20 amp breaker because the wiring is most likely 'sized' for the 20 amp load and -may- overheat if a 30 amp load is used with wiring sized for a 20 amp load."
Some (limited) exceptions may exist for things where "duty cycle" come into play.
But in general, for some "outlets" wired up on a 20 amp circuit breaker then the answer is almost always "No, don't replace the existing 20 amp breaker with a 30 amp breaker".
nmk_61802
Central IL
Wrong thread, he is talking about a heater here.
Seems to me like he is asking about a Maxjax like everyone else believes:dunno:
Don Ivey
Smithfield, NC
gezn2
SW WI
You might get by for years...
I've found myself tearing out and redoing 'safe enough' stuff I did years back as I learn more about what's required by Code.
The wisest advice I ever heard about wiring is that every single article in the NEC got there because Somebody Died.
