remote light for liftmaster 3800
ktm010
wiring my garage now and planning on two liftmaster 3800 openers, I wanted a unclutterd ceiling so would like to have one light operate off both openers. I contacted liftmaster their optional light needs a receptacle and would come on by radio signal from opener but both cannot operate one light due to they have only one channel per light any ideas ??
Teken
The Bad Lands
You would like to have one or the other GDO to turn on the remote light? :headscrat
Teken . . .
K
ktm010
yes, even if they both could turn on say one of my permenant lights. other wise for there lights two outlets in the cieling and two seperate lights . Conventional openers would have lights on them so it wouldn't be a question, but these openers mount to the torsion shaft. And again looking for a un clutterd cieling. Just tell me if I'am being stupid:willy_nil
djjsr
In the cornfields
That remote light that comes with the 3800 has 2 light sockets. I think there is a receiver/controller in the housing that turns on both of the lights. Maybe you could install the second receiver/controller in the same housing and have them turn on 1 light each.
Maybe.
GeorgiaHybrid
Extreme NW Georgia
When mine were installed, I had one light that would turn on when either door 2 or 3 were opened. He fixed it in just a minute but after seeing that, it can be done, just don't know how.
pattenp
Virginia - USA
You program the opener not the light. One light should be able to be operated by two openers. I think Liftmaster gave wrong info.
SHawkins87
Central Kentucky
You can have multiple openers operate a single or multiple lights. I have two openers and four lights. Each opener operates all four lights.
There is a button on the light that you press to put it in program mode. You press that button and it's LED starts flashing. You then press the light button on the keypad to program it. Repeat this process for the second opener.
If you have multiple lights you just repeat the process for each light.
