Torque Extensions?
SCguy
Blackville, SC
Are Snapons the only ones worth having, or are there other brands that would be fairly good? I see Genius all over the place, are they any good? Pretty much what I'll need is a 80ft-lb and a 100ft-lb.
RD
DavidtheDuke
Well, SO's torque extensions (Blue Point right) are lifetime warranty, as are other brands too, but I'd say getting SO to warranty it would be much easier than any other 'website brand'
nissan_crawler
Wichita, KS
I'm not a fan of them, first, you can overpower them if your impact has more power than they were designed for. Second, I've checked them with a dial torque wrench before to see at what point they would break loose after using one, and the numbers were all over the damn place. Snug them down with the impact, and torque to proper specs, IMHO.
Even changing tires for 14 months, I wouldn't use one, always used the torque wrench.
Deafautotech
Indianapolis, Indiana
i has snap on 100 ft lbs torque stick and it is great for me to use it every tire rotates but problems is sonetime my IM5100 got changed to low set of torque itself (it is older impact wrench but it still work good...) but i am still always use torque wrench so i can sleep as good night!!! :thumbup:
Even i can use it for else like pinion bearing nut or axle shaft's nuts... then i can do torque wrench on right way...
Fedwrench
Valley of the sun
As discussed before, there are a few varibles involved that affect the torquestick's accuracy. The impact wrench, volume and PSI of air supply, the user, and the age of the torquestick. You should compare a given torquestick accuracy against a torque wrench at least quarterly to ensure things are working as you think they are.
Moose-LandTran
The Brink of Insanity (England)
From all the different "torque gimmicks" i've seen, there's nothing i trust over a torque wrench or personal judgement. having also working in the tyre trade, i just wouldn't trust these sticks.
at work, we have 4 or 5 torque wrenches, i can tell by feel that they're way off. they get used to undo bolts all day, they just chucked around and dropped and they never get wound back either. i can feel that they're clicking at about 35lb/ft not the 70lb/ft that they're set to. i use either my breaker bar, my gun or my own torque wrench over any of them. you get used to putting down the right torque by feel. not as accurate as a good torque wrench, but far better than a **** one.
Ducroix
Tampa, Fl
i prefer torque sticks over the extensions but I have some that are made in taiwan and they work great and are pretty accurate just dont go to cheap and you should be fine no matter what brand
eschoendorff
You just confirmed what I have long thought about those things....
Merkava_4
Clovis, CA.
I use that S831 flex head as tight as I can pull; them lug nuts haven't come off yet. :bounce:
Deafautotech
Torque wrenches? Of course they're going to be off if not wound down. Has anyone checked their torque sticks before?
lot of time i use torque stick and it do meet the torque wrench specific but some time i caught my IM5100 adjust itself so i just keep use torque stick so it can get vehicles go on shop floor fast and torque wrench it quick... :beer:
DavidtheDuke
Have you ran a lug down and check the torque to see if it matched the specifications of the extension?
Fedwrench
Valley of the sun
"Unusual?" BAWAHAHAHAHAHAHA!!! That's putting it nicely. :bounce:
:lol_hitti :lol_hitti :lol_hitti
I think it's all about the length. That cardboard box contains his longer unused tools. I don't get the cardboard boxes. I was expecting velour or at the very least purple velvet lined jewel boxes to hold Merkava's polished tools. I'm surprised that he hasn't touched the paint up on the sledge.:bowdown:
