Wingnut65
The trim on #2 looks great and the edge banding on the shelves is coming along.
For tool panel #1, which Weldwood did you use? They offer many varieties. My first thought would be for the contact adhesive, coat both sides and wait till dry to the touch and the two pieces should not come apart. I don't know how wood glue or other adhesives would work for that condition.
As a remedy, try a hair dryer to heat up the aluminum and the glue below and then run a hand roller over it. Or, I like M_P's suggestion... load it with tools.
EDIT: Forgot to mention an alternative material... P.Lam. Plastic laminate counter material that is aluminum. Both Wilsonart and Formica offer it for countertops and cabinets. Since it is made in a factory, it is stable and won't have attitudes like yours does. P.Lam is easy to cut, trim, finish and mount. HD's, Lowes or other big box stores either sell it or can get it. Just a thought. It would work great for big flat surfaces like you have.
(And I mean that in a good way.) Because of seeing your awesome restored old woodworking tools, it has inspired me to look for the "jewels" that other are passing over. I found a King Seeley jointer/bench saw combo mounted on an original base for $15. If not sold, it was going to the scrapper. I did a quick restification on it, and the Painter's Touch brand of gloss gray paint was identical to the paint on the inside of the base and underside of the jointer. I added a set of locking casters to the base from Rockler for ease of moving it around.
