Urinal in the garage?
PAPASMURF
Does a urinal have to go in the septic or dirty water? I have a hook up for the sink there and was just thinking of plumbing a urinal there... Thanks. Also maybe some pics of Urinals/bathrooms if you have em in the garage. Thanks guys..
P
PAPASMURF
thats what I was thinking just not sure if the waste has to go to the septic line or the dirty water line since there was no "2's" going down.
mtwaterguy
If your sink hook up was installed by a plumber your sink drain should be connected to the septic.
P
PAPASMURF
sweet!!! It is a track home and they just have the hookups there I just have to go buy the utility sink kit for it. Now I have to talk the old lady into me putting a urinal in there...Then she will know it's mans land. Hahahaha
larry4406
Northern Virginia
Don't know what you mean by "septic" or "dirty water". The waste water all goes to the same place - septic field or municipal waste. Some buildings have "gray water" systems but those are usage of non-potable water for non-potable uses (i.e., flushing toilets) but in that case it would still go out the sanitary.
The urinal hooks up quite easily, at least mine did.
jay50
I "plumbed" a funnel to some ABS pipe through a hole in the wall. It drains onto the nasty neighbors' fruit trees:bounce:
So that is what is causing their trees to die at that location...you are pure eeeviiil.....:evil::lol_hitti
z28toz06
Connecticut
If need be a 5 gal bucket with arm and hammer cat litter works great also. I know guys that keep it in their truck for emergencies. it cant spill and if it does it vacuums up.
Chris 50
LaPorte IN.
I have a good friend who is a local sign painter/pinstriper that had a similar setup at his old place. But after applying his trade, the area around the funnel was painted to look like a urinal!
e-tek
Saskatoon, SK
Actually, the GD apples on his tree where HUGE last year!! Must be all the 'nutrients' going through my system!:wtf:
Now that is something I'd like to do! RIght now, I have a picture of George Bush surrounding the inlet - if you know what I mean!:bounce:
:beer:
tassue
a friend of mine...has a tube running outside into the ground 4-6ft
the "piss hole" is a cut in half quart of oil bottle ....works like a funnel...
he uses the other side as a lid to close it off.......over 20yrs and still works great
edl
Southeast, US
great suggestions - another one...steal some diapers...makes disposal quick and easy...finally, if all else fails, hit the pot you drain your oil into...can't make it anymore toxic than it already is (well for most of us anyway!!) :)
dcg9381
Austin, TX
There are allowances around here to do drain systems that are non-tanked and non-septic. Think kitchen drain. I wonder if a urinal would be allowed as it doesn't deal with solids?
e-tek
Saskatoon, SK
Talk about a blast from tbr past!
FWIW, I'm not still peeing on my neighbours trees. We moved to an acreage with an attached garage and there's a terlet just inside. Plus as I've gotten much older I don't pee as much - or as easily - as I used to.
Carry on.
Ton ton
Page County,VA
Carry on.
How are the trees doing? Did they die yet?
drmarkr
Tucson
Carry on.
Just seeing you posting makes this a blast from the past!!! lol....hope you're doing well!
nadogail
Coronado, CA
Carry on.
I have noticed that with my advanced age I seem to be peeing more frequently than I did when I was not yet a Senior.
