What color
Escalade132
Hey everyone I have another question since the house I just bought the garage isn't painted. Can you give me what the best color to paint it, the garage I have now is a beige color I was thinking maybe Grey, I don't want white.
Hanks
Sent from my iPad 3 HD using Tapatalk HD
Gary S
Bismarck, ND
Common sense says you paint it to match the house..........or you could go with the pink with lavender trim.
1steve
Tennessee
I will third pink with lavender, no one will break in, another plus.
Seriously match the house.
E
Escalade132
That's the way I have it now, but in the new house I was thinking a light gray color. I've seen on here where a lot of people use gray to make it brighter and looks good.
JimVonBaden
Northern Virginia
Light and dark. It can be blues, shades of gray, even greens and reds.
Jim :cool:
Keep
Oshawa, Ontario
Depends what you plan on doing in the garage.
If its a working garage, paint it white to reflect the light better, a light grey would be alright as well.
If its just a parking spot, match the house.
larry_g
oregon
Are we talking paint on the inside or outside of the building?
lg
no neat sig line
E
Escalade132
It's the inside and I will detail and clean my car in it
Sent from my DROID BIONIC using Xparent Purple Tapatalk 2
RECox286
South Joisey (yeah, that is part of the USA)
If you will only be using the garage as a wash and detail area, then
I would opt for Pink, with a Lavender trim. However if you were to
upgrade the operation to include oil changes, lube jobs, and other
light maintenance, I would go with a flat White which hides a multitude
of surface irregularities. I would guess that the garage sheetrock is not
finished quite as well as the house's is. Use a good ground coat
to seal the sheetrock and to give the finish paint something with tooth
to adhere to, other wise the finish will soak into the bare rock, or
won't stick well to the paint that is there already (if there is already
paint there).
Uncle Bob
The Frisco Kid
Central Texas
I would go with a matte/flat pure white base with just a hint of blue tint to it... this will really make the walls reflect light and brighten the work area.
BWS
Mnts of Va
Look at how schools are painted.........****** green up to arms length,then off white above for lite refraction.So,green iffin you're flick'n alot of buggers.....maybe gray if you're sling'n shop crud?
Our cabmet shop is wood dust biege....with off white above.It does make a difference......meaning,anyone who's poo-pooing certain colours must be either,not producing much or is so clean the chit never gets on the walls?BW
Cardboard Man
You said you didn't want white, but you also asked the best color to use. White.
Most garages and shops don't have enough light and white will help to brighten a poorly lit work space. If you're detailing a car, you need all the light you can get, especially down low.
Kevin54
MEMBER EMERITUS
Urbana, Ohio
Hanks
I'd paint it whatever color you want to paint it, except white. You might possibly want to paint it gray. :willy_nil :dunno:
:+1: and I'll go against the flat paint grain and say high gloss white with the longest nap roller you can get. this should leave a slight stipple effect, and the high gloss is easy to clean for splashes, and easy to keep clear of dust.
Imperfections the sheetrock/tape/mud? Its not that difficult to feather it out and get it smooth...
If you want to have an accent color on the lower half, fine, but even there I like it light as it helps when I'm trying to see in "dark" corners. a lot... Maybe just mid wall stripes that carried your car color theme? :dunno:
I painted my garage interior as described about 25 years ago. It is still holding up well.
