Tool Box Foam, Shadowing
Chamkila
NYC, NY
Hey guys,
its soooooooooo damn expensive, anyone know where to get it on the cheap? or i have to pay like 100 dollars for a few sheets?
thanks in advance. :rocker:
jetmech09
Camping foam from walmart. $6. I can't seem to find it on the website, just go to a store in the camping section and you will see it. It's blue, comes in a roll.
rsanter
visalia ca
how thick is the camping foam??
the best deal I have seen is on the cheap mats at like HF. they are 1/2 thick so they will shadow really nicly
bob
ckadams00
Seattle, WA
I've picked up a couple of things:
1. Foam insulation from Menards - &8 for a 4x8 sheet 1/2 thick. Can be spray painted. Not as good as the flexible foam, but if you need a lot cheap this works for my carry around boxes.
2. Yoga Matts - these are much better than the cheap foam and 1/4 thick - I bought a few on sale at $5 each. To thin for shadowing but great as a liner.
3. HF!
jetmech09
Is the cheap stuff any good?
I had the cheap stuff in my work box until I had to re-shadow it, then I used the stuff they gave me at work because it was free. I liked it. It resisted skydrol and other chemicals. It's all closed cell foam so I'm pretty sure its about the same quality across the board.
joecon
I buy it at sears they have it buy the tool boxes.It comes two sheets with a knife and paper to lay out your set up.
markitsnappy
midwest
I just bought this stuff from home depot for my "new to me" tool box. It comes in rolls of 18inx4ft for 5.99. I think it works great and looks pretty good. It's not thick enough to shadow but makes a pretty good liner.
Hootbro
Delaware
Not all foam is good for tool box shadowing. You want some polyethylene foam in either 1.7 or 2.2 pound density. Start getting higher density and air gets trapped with moisture between the tool and foam and then you start having rust and flaking chrome issues.
I have ordered from here with good results.
http://www.closedcellfoams.com/polyethylene.html
49 ford f-3
This stuff is awesome. It is cheap and easy to use.
I did step by step directions on my blog on how to shadow your toolbox with foam.
