spring clamp pliers?
Buckgnarly
VT
I have the cmans you listed, real lifesaver...no idea how i lived without them!:thumbup:
Humble Mechanic
NC
Like most tools, DON'T buy cheap. I have a cheap pair and I HATE them. I don't use them because they split under the clamp.
The good ones work really well, but the cheap-o ones are aweful.
6-Speed
I was struggling with heater hose clamps on my Honda Odyssey last weekend using various pliers. I thought to myself ... there has got to be a better way. I'll have to invest in a set of Mayhews.
House Sparrow
Lewistown, PA
I have the Blue Point set from Snap-On. USA-made, and they make quick work of those despicable squeeze/spring clamps. The cable broke on them once after much use. My dealer replaced the cable under warranty, and I've had no trouble with the pliers since.
I don't know how much this will help, as these are ancient (I've had them for at least 35 years and they were old then...) Diamond KC-16's
Notched so you don't slip like std pliers, and for straight on, or nearly perpendicular to the clamp.
There have been times I could have used the cable activated pliers, but these are still 10X better than standard pliers..
gtrotter
southern Indiana
I have a blackhawk version of these. They have a ring you slip down the handle to hold the clamp compressed. Makes installing and removing clamps a piece of cake.
6-Speed
The Mayhew and Snap-on look to be the same except for the handles; both sets are made in France.
jjjrmx5
Cincinnati, OH
If no truck or if you care to save your $$$, buy the C'man units.
C'man are made in France as well by the same mfgr.
Same units. Lifetime warranty. Better price.
:thumbup:
6-Speed
:thumbup:
Does the Cman pliers have the ratchet mechanism that the Mayhew and Snap-on have?
jjjrmx5
Cincinnati, OH
No, but both the C'man and the Mayhew the Op lists in his orginal link are both pull and lock pliers and non-ratcheting.
Once you get into the ratcheting units, you are into the $75 to $105 range.
(The Astro's look like ratchting units or kopykats but i have not used them)
Well above the $39 C'man units for the good ratcheting pliers.
Those are nice to have, but not really needed.
Yeah, I've found that a lot of the time when I can't get regular pliers on a clamp easily, I can't get this type on easily either. I've got the Blue Point version FWIW. Maybe one of the others is better.
dankicksass
New Jersey
If one wrenches for a living, ya need em. Cable and direct action, if you buy the OTC 2-pack and the Craftsman or Astro cables you're in it about $50. My favorite pair says Kobalt on it, though I don't think it's in their current lineup. Nicer action than OTC.
bgott
Houston, TX.
The last set I had were Astro-Pneumatics. They were a $5 pawnshop find and they lasted for years. When they screwed up it was the ratchet that went, not the cable.
