anyone ever use a 7mm hex?
shurik06_83
vw/audi mostly 6mm hex but the odd time they will drop in a 7 to keep u on ur toes
Hal
Vermont
VW caliper pins, I think. Anyway I didn't have one, and ground down a bigger one to fit.
franzdom
NC
2003 BMW e46 brake pins, also I believe Bilstein struts on our Volvo & BMW. Due to low clearance in the rear brakes and needing to go through pass through sockets in the struts I have just about every kind of 7mm hex socket.
C
cbracer
Costa Mesa, CA
Re: anyone ever use a 7mm hex bit?
Ditto. That size is used in oddball ****.
Why do you ask?
Guess I screwed up and asked if anyone used a "7mm hex" when I should have asked "7mm hex BIT" ..... Trying to decide if I need one in my hex bit set.
jjjrmx5
Cincinnati, OH
I just assume you meant bit socket when you asked, as doing brake jobs or removing hefty fasteners with a "L" type allen hex key is not ideal nor recommended.
The best metric hex bit sets should have everything from 2 (and 2.5) up to 10 minimum (or bigger if doing major maintence or have a vehicle that takes teh big hex bits for oil filter cartridges and the like.)
franzdom
NC
It is always a good idea to use a torque wrench when torquing brake caliper bolts, thus the L style wrench is not an option.
admranger
Las Vegas, NV
As mentioned earlier, everything from the '80's on BMW brake caliper guide bolts are 7mm (though I haven't checked the ones on the E90M3 yet...).
I have several 7mm 'allen' head sockets just because of this.
bfd
they made a special tool so you could use any 7mm hex with a peanut butter wrench :)
I happen to have it.
That's interesting. Can you post a picture of that tool? My old Campy C-Record crankset required a 7mm hex for removal. Then in the mid90s, they conformed to the standard and are now using 8mm crank bolt extractors. Good Luck!
franzdom
NC
7mm allen key holder, can be used inside a 15mm traditional crank bolt wrench:
with a 7mm SO hex socket in it:
a blurry pic of the Campagnolo pin tool needed to remove the 7mm crank bolts from the crankset, they used reverse threads by the way
A reverse threaded Campagnolo crank puller to use in case you removed the hex style and use a traditional 15mm crank bolt instead, note both parts are LH threaded not just the engagement part, these guys were definitely OCD:
Another favorite of mine from that era, the C-Record hub dust cap remover :drool:
bfd
Very nice! You have a nice set of Campy tools! :beer::thumbup: I've never seen that allen key holder, but like that you use a SO 7mm hex socket. The left hand thread crank puller is a very nice tool. I have the normal "righty" version. I also had that hub puller, but sold it when I gave away my C-Record hub rear wheel.
I agree that Campy tools are OCD - my favorite is Campy cone wrenches - simply sublime. Good Luck!
