cbracer
and if so for what?
Ford disc brakes is the only thing i can remember using one on.
Chrysler disc brakes as well. I think the front brakes on RS minivans, specifically.
80's BMW brake disc caliper bolts
Guess I screwed up and asked if anyone used a "7mm hex" when I should have asked "7mm hex BIT" ..... Trying to decide if I need one in my hex bit set.
Older Campy crank arms bolts were 7mm. (bicycle)
they made a special tool so you could use any 7mm hex with a peanut butter wrench
I happen to have it.
That's interesting. Can you post a picture of that tool? My old Campy C-Record crankset required a 7mm hex for removal. Then in the mid90s, they conformed to the standard and are now using 8mm crank bolt extractors. Good Luck!
