Sun Distributor Tester
strombecker
I have a sun master distributor tester, and was wondering if anybody has a manual or wiring diagram for them. I want to restore mine. Mine takes a six volt battery and looks like two other baterries on the face of the unit. Says model number is MDT, about 1956.
Thanks Terry
[email protected]
floyd
MD
Check with these guys: http://paramountd.com/
Looks like he may have some literature as well (listed under Parts for Sale):
Instruction Manuals - $25.00 each Model 504/404Model 500/400Model 600
These are brand new manuals for Sun distributor tester machines. Three different manuals covering models 504/404, 500/400 or 600. They are 16-page instruction manuals used when testing distributors. I had a local printer reproduce the original Sun manual. It is NOT a cheap copy of a copy! The cover has the same heavy paper stock as the original. Nice bright white pages. Replace your old, dirty dog-eared manual with a sharp new one. You can use these instruction manuals with any Sun tester as they are mostly the same hook-ups and have very similar features.
mikeyr
Santa Barbara, CA
I was going to send Mark at Paramountd (link above) my unit for a rebuild but he convinced me that I could fix it myself, sent me everything I needed, lots of little electronic parts and clear instructions, fixed it myself with his help. Saved me at least $300 from sending it. I documented the entire process with pictures and you can find it with Google.
There are PDF's out there of the manuals and wiring diagrams, I found them online with a google search but I only grabbed the ones for my model.
mrpowderkeg
Bismarck North Dakota
With a multimeter you can fix it. I have done it. Mark is a good guy, and the other guy is Robert Masters http://www.distributortester.com/about.asp Both will hook you up with what you need.
I repaired my 506. I had a bad diode, replaced some capacitors, and had a burned out bulb that I replaced with one from radio shack, and I made it work. Where there is a will their is a way! The wiring diagrams are needed. Mark offers a bulb testing service to see if that is the problem.
Riverside, Ca
If you need the SUN rubber like battery tray/s I may be able to help depending on when I find them again.
Hello,
I just bought a 1955? MDT and I need the Battery Tray/Pad if you can help me. I also need the Manometer metal housing. I can make the glass tube if needed.
Thanks,
Kevin Kline
Fullraceflathead
Steve in Mi
Mid Michigan
Hello,
Thanks,
Kevin Kline
Fullraceflathead
Been away for awhile but if you are still in need of a battery tray let me know. I can't help with manometer housing. Steve
Steve in Mi
Mid Michigan
Battery Trays;
Still haven't located them but when I do it looks like strombecker asked first and then Fullraceflathead - I'll attempt to contact in that order.
Fullraceflathead - I sent you a PM.
