Ratchet id help!?!?
zoomieport
The Mall City
Came accross this 1/2" ratchet at a garage sale today. Not sure if I want to clean it up or not, so I can't find a maker on it...
On the "male stud" there is what looks like an "H inside a triangle" stamped opposite the BB side, maybe...?
It's marked Made in USA.
And it stamped with "R-718".
Any and all help is appreciated, thanks!
Mike
Herbrand used a Diamond-H logo, and is known for male drives, although I don't recognize that particular ratchet, which is early/pre-modern, or the model number.
Oooo, that's a good one, LG. NB did make an early ratchet with those 4 studs arranged like that, but I thought it was an open style. And it doesn't look like an NB model number either. But what do you make of the Diamond H logo?
Flatintoone
West Bend, WI
Looking closer, it looks like that should be a 9/16" hex. Like I said above, I bet it has an adaptor in it, or has been modified somewhere along the line.
4x4gearhead
New Hampshire
A lot of times I find those male drive ratchets dont have the oem square drive in them, could have come from another ratchet, ran into this on an old walden.
lbgradwell
Oakville, ON
A lot of times I find those male drive ratchets dont have the oem square drive in them...
That's certainly true. Mike, is the drive plug removable on your ratchet? It appears to be a bi-directional model so a removable drive-plug would not be required. It is reversible, correct?
Z
zoomieport
The Mall City
Thanks!!!! It looked like it "belonged there"...
Not a bad pick up for a change!!!
