cut off wheels
holt2ton
Michigan USA
In my right angle die grinder I use the thinnist width that I can find. Usually around .035-.045" in thickness. The thinner wheels have less wheel to metal surface contact and lets you keeps the RPM's up. I usually get them from MSC Industrial supply, But I'm sure if you did a 'net search you could find many suppliers for them.
jjjrmx5
Cincinnati, OH
Best or affordable?
I like norton discs. 1/16" th. discs are great for 1/4" to 5/16" thick steel plate mod. work. i also keep the thinner general cutoff Norton discs for alum or thin bar stock work or for exhaust, bicycle , etc mod. work.\
1/4" collet.
Norton discs are USA made.
blacK20
The 3m green wheels are the best I've used. They are expensive though at over $5/wheel
