Compressor loosing air someplace
Mustang67ford
I finally got my 60 gal. Air compressor hooked up but am loosing air someplace. I pressurized to 125 psi and it went down to about 85 psi over a 2-day period. I soaped all joints but found no leaks. Is it typical to loose some air over time or is this not normal? How can I go about finding the leaks that is better than soap?
rlitman
Long Island
I use a commercial bubble solution (mega bubble is the name that comes to mind), but a leak like that will be VERY small and hard to find.
Could it be your quick connects? You may have to dunk them under water to see.
Sureshot
Bridge Creek, OK
Could be going back through the checkvalve. Pull the fitting off the compressor and see if it is going out the indoor sorta thing. Also the bleedoff on bottom. Possible valve leak.
ImportTuner
I had similar issues; I redid all the connections using Permatex High Performance Thread Sealant paste after removing all the teflon tape .. No more leaks :thumbup:
