samert111
I was one of the buyers of the 24 or so Rotary lifts out of Canton, Mi that the deal fell thru recently and after talking to the installer that Frank recommended to me, he came across a Forward DP97A - 9000 lb lift that he was going to remove from a Walmart in Southwest Mi. So I bought it based on a few photos, no $$ down. Its 12 years old like the Rotary’s that Frank was going to get and apparently Walmart did not let their employees lift a vehicle more than 3ft off the floor for safety reasons I guess, so this lift has never had a vehicle up high. I now know this to be true because they had attached some mounting brackets for air lines or whatever about halfway up the columns and the self tapping screws went thru the column and would have been in the path of carriage if it went up that high.
So they brought it out today to install it and it looked real good. Well after drilling a test hole in the concrete it seems my concrete guy from 15 years ago F@&K’ed me and only gave me 3” instead of the 4” I wanted, so the lift is now sitting off to the side of my building and I need to cut out and replace some concrete I guess.
I have a couple options and was wondering what would be the best way to go strength wise.
1. Cut out a 4’ x 4’ section where each column would go and pour a replacement concrete column 2 ft deep with underpinning to the surrounding old concrete floor.
2. Cut out a 7 ft x 14 ft section and pour a 6” deep replacement pad with underpinning to the surrounding old concrete floor? The reason I would go 7 ft wide is that would get me to a current crack control joint and also eliminate an uncontrolled crack in the middle of the floor in this area.
The amount of new concrete and overall cost is about the same for both options but I’m a little concerned with the stability of the 4 x 4 x 2 column over the larger overall larger replacement pad. I was told drilling and pinning into the old slab is also a good idea but the guy that quoted cutting out the old concrete said that he was concerned it would compromise the strength of the old concrete due to it being only 3” thick.
So what say you all, especially you concrete guys?
