Show Your Tools Working.
PRH44
Indiana
Installing new 750 KCMIL 15,000 volt feeders for the Deep Rock Tunnel Project. They will bore down 240' the turn horizontal and go 7 miles with an 18' diameter tunnel bore. This will connect two waste water treatment facilities so they can literally pass **** back and forth.
Setting up the cable
Feeding the cable and applying the lube
Cable passing through one manhole
Using a Dynamometer to measure pulling tension
Sorting the cables after the pull.
Skin
Boston
Quick O2 sensor replacement today
And heres the original O2 sensor re-installed because the replacement wasnt Calif emissions! :lol: This is why you use O2 sockets and try not to snip wires unless you're 100% positive.
crewchief888
NW indiana
one of the "tools" we had working for us at the time, decided to flop this bobcat over off the stands.....
missed my toolbox by about 6".........
:beer:
SMKS
USA, planet Earth
Here's my most recent project. Wheel bearings on my 1999 Nissan Frontier.
Tools used:
-Wright 3490 ratchet
-Truecraft made in Japan ratchet
-USA made Truecraft sockets
-Made in Japan Makita electric impact
magova1104
USA
A few shots in my job and some tools that I use everyday. Ingersoll Rand IQV are my favorite cordless.
metaldad
nw indiana
looks like calumet plant.
i thought they already connected calumet to stickney
metaldad
nw indiana
Aligning a 500hp motor to a compressor. to within .002 total. no lasers.
the dials weren't zeroed yet.
NC-Fordguy
Used the saw to pretty much cut out this section of rust. Air chisel and some spot weld cutters.
This is the worse case of rust that I've ever had to repair. I figure about 70 percent of the sheet metal is going to have to be replaced.
I'll coat the inside of the frame after I move the fuel line and wiring on the drivers side.
The passenger side just needs to have the evap lines removed.
99_xc600
OK, I'll contribute. 2005 Pontiac Grand Prix LIM Gasket replacement. This was from Saturday. Not a bad job took about 4 hours.
sdguy55
Pierre, SD
Replacing water pump on a C15 with regen system
<a href="http://s1268.photobucket.com/albums/jj571/sdguy555/?action=view&current=2012-07-23102736.jpg" target="_blank"><img src="http://i1268.photobucket.com/albums/jj571/sdguy555/th_2012-07-23102736.jpg" border="0" alt="Uploaded from the Photobucket Android App" ></a>
<a href="http://s1268.photobucket.com/albums/jj571/sdguy555/?action=view&current=2012-07-23170318.jpg" target="_blank"><img src="http://i1268.photobucket.com/albums/jj571/sdguy555/th_2012-07-23170318.jpg" border="0" alt="Uploaded from the Photobucket Android App" ></a>
<a href="http://s1268.photobucket.com/albums/jj571/sdguy555/?action=view&current=2012-07-23170341.jpg" target="_blank"><img src="http://i1268.photobucket.com/albums/jj571/sdguy555/th_2012-07-23170341.jpg" border="0" alt="Uploaded from the Photobucket Android App" ></a>
durallymax
It Fell off I swear
Cam/lifter replacement on Pumpe Duse TDI
Pulling tractor head and bent pushrods.
Duramax Headgaskets
Allison 1000 Rebuild
Sisu Turbo replacement
Replacing DEF sending unit on Agco
pepi
Woodstock, GA
Day job memory upgrade completed.
Checking hardware to see if the machine recognizes it.
For fun
Checking progress, needs some buffing and a little wax.
JoeFin
NorCal - where the Rednecks Race
Here is a pic of me removing the surface hardening on a piece of Chrome molly I scrounged from a hydraulic cylinder that had seen better days
I used to make a "Neck Bolt" for a Sportster - Evo transformation a guy was doing for his brother coming back from his second tour in Iraq.
This was way before the "Harleys for Hero's" foundation was ever thought of and was just one man's way of saying thank you to his brother. It was pretty tough because the guy couldn't draw mechanically and I didn't have the frame or parts he did to measure from. More then once I had to call around to the local Harley shops to see if they had a particular model on the shop floor I could go measure some parts on.
Of course at the time they all thought I was crazy because once again there was no such group as "Harleys for Heros" And to make matters a little more difficult the unit he was stationed in over in Iraq kinda borrowed Hue Heffner's logo.
I think this might have been part of the "Brake Stay" for the rear wheel
Here is the finished product with the Brake Caliper installed
I can't remember what he filled the inlay with. He was a powder coater and I think I bought some Gold Foil and had it shipped directly to him
Then of course he needed a good set of Forward Controls to go with that Brake Stay - so once again here we go with the measurements thing again
A little bit of this a little bit of that - and here is the finished product - sorta
Anyway the returning vet was really happy with the whole thing - I think his wife even wrote thank you letters to all the guys who contributed to the project. There was about 6 or 8 of us from all over the country shipping parts back and forth customizing them and stuff helping this "Brother from another Mother" put this Harley together for his brother coming back from Iraq
Eventually I think the build made it into Iron Horse magazine
GTA Matt
Zebulon, NC
Neat thread! Kinda hard to catch tools 'in action', but I've got a few shots
Aftermath of replacing Mercedes subframe, control arms and ball joints
Engine crane gets a workout
And my brake line benders and flaring tool in action
Challenger_2MBT
Framingham Massachusetts
Complete restoration to an ex New Haven FL9 locomotive #2019. First, removing all rust from the car body. Then, welding in new steel, sanding, and etc.
Milwaukee grinder
Snap-on ratchets; Snap-on MG325; LED rechargable work light; PT210 die grinder and other tools at work.
Skin
Boston
doing a complete in and out restoration (e.g. engine) or do you only handle the cosmetics?
Challenger_2MBT
Current welding project. Lots of fabricating!
And the tools I used today. Getting ready to clean them up & put away
gearhead1
NC
Derby cars and anything else that breaks....
gearhead1
NC
302 rebuild, Circle Track car, Intake gaskets on a 3.1GM, Race win
ClrkLndeKmt'su
Dayton, TN
Neat thread. Here is an ESM15S in many pieces. All done in a 10 degree freezer. Cordless tools don't like 8 hours in the cold fyi.
Sent from my greasy Galaxy S4 using Tapatalk
Heavy tech
Tear down on a cummins in a genset
Checking the timing chain in a 2.2L GM before install
Getting ready to pull the track frames off a D6T
bodyguy16
QC, Canada
Replacing quarter panel / rear end panel and tail lamp pocket 2012 camry
Sent from my SGH-I747M using Tapatalk
dodgemike
Great post! I love it all but usually
the bigger the better. I guess that
is why i played in the dirt with the
big Tonka toys most of my career.
Sent from my SCH-S720C using Tapatalk 2
