Ok so Ive made some decisions regarding what to do or whats going to be needed to properly run my sandblast cabinet. Ive decided that Im going to pick up an 80 gallon compressor. My problem is that I have no 220 in the garage. Option: Run 220 out to garage at an added cost and labor on my part. I basically came to the conclusion that I would install the compressor in my basement shop where ill be able to wire in the 220 line more easily and also have an opportunity to pipe in lines for my indoor shop. okay so then Ill still need to get that air out to the garage. I figured that I could pipe everything inside for my indoor shop while also running a line to the back of the house where I could have a short section of pipe with a coupler exposed at the back of the house (kinda like a garden hose spigot) i would then run all of the piping in the garage and basically do the same where a short piece of pipe with a coupling would be at the back of the garage. I would then only need to run a short length of hose from coupling to coupling (approx 8ft my yard is very small) and then this way I would then have my air supply to my garage. I like the idea of the compressor being inside my home for several reasons... I wont have to hear the thing running while im working, less chance for someone to decide to steal it because the wont see it, and as already mentioned not having to run 220 out to the garage. i just wanted to get your opinions on my idea of getting the air out to the garage. think it would be my easiest solution.
