Mmfh
MEMBER EMERITUS
Hey there,
I'm starting to work this out in my head so I can get this figured out and start collecting the materials I need to get this done.
My Home has not had A/C before and I want to add it. I have a Condenser unit outside, Used, a "A" coil that goes with the condenser. New furnace installed.
I bought several years ago a used furnace with the condenser and "A" coil so I could add A/C to my house. Poured a small pad outside for the condenser, installed the furnace and that is as far as I got.
Furnace failed and had another unit installed, told installer that I was planning on using the A/C stuff I had so the furnace they were installing had to be able to work with it.
I know I need to run the line set from the outside Condenser to the "A" coil inside the furnace Plenum. What I really don't know right now is about the flow of air over the "A" coil. Do I just set it up in such a way that all of the air from the furnace blows directly through the coil? Seems this would slow down the air needed in winter for heating.
The Plenum is just a 2' x 2' x 2' box under the furnace, I figured I would open that up and make a ledge on two sides so the coil could sit in the air path. Run the lines to the condenser, add service ports, wire it up, call an HVAC guy to come and charge it up.
You can see now that I have very "Basic" knowledge at this point of how this is going to work. This is the beginning of my research, can you add any info that will help me with this project.
I can't afford to hire this out, so please don't tell me I should. If I can't do it myself I won't have A/C again this year. I'm determined to make this happen.
Thank You very much!
Mm
Mm
what he said
