What is a good test light to use?
gnx547
Can anyone recommend a good test light? I have bought the cheep chinese ones from the auto parts stores and they don't last long. The alligator clip spring always looses tension and light is not that bright. What is a good test light to buy that has a bright light?
oldtools
Becareful what you are measuring with a test light (regardless of brand). You can damage sensitive electronic. Use a DVOM instead or a electronic approved test light.
franzdom
NC
I have a few DMM's but no test light. Specific recommendations would be good, I see SO for instance has several and their website doesn't compare them very well. Does Fluke make one for automotive appropriate use?
alan camby
South of Indianapolis, Indiana
Craftsman makes a decent one. I have the Model 21013 and like it.
As already mentioned, I was taught not to use them in GM's ASEP program. They can pull more current than some circuits can handle.
crewchief888
NW indiana
i mainly use a test light for quick tests on main wiring, batt to starter, to main feeds.
FWIW
i work on constuction eq,
dont mess with automotive too much, and when i do, i'll ussally grab a DVM
:beer:
csargents1546
Westminster CO
The Shop
Texas
Power Probe 3!!! :rocker: It's a basic voltmeter, polarity indicator, test light, circuit tester, flash lite, ...... And it's the first thing I grab when I need to do any electrical testing/diagnosing.
sickboy motors inc.
california
I bought an Equus test light (2 color power and ground) from the snap on dealer. I have bought snapon test lights before but find i like using the Equus more often. Easy and efficient.
Stick
Alaska
Same here. Test lights are for hacks
Bah!
They are just a tool like anything else. I still use a testlight on occasion, same as I use a generic logic probe, powerprobe 3, my fluke 179, snap-on vantage, vantage pro, or even a sealed beam headlight. The use of it as a tool doesn't make you a hack, but using it without understanding it's benefits as well as limitations does...
As far as what I'd reccomend, my favorite test light is the red 24V snap-on one, because it doesn't blind you when you're working under a dash. The one that comes in a pouch with the connectors you need to test metri-pak terminals is nice (the ability to switch ends around as needed), and it used to be a GM recommended tool IIRC, but the kit isn't cheap at ~$250 last time I checked.
Steevo
43.49600, -112.04300
For the current high-tech mechanics who have to deal with sensitive circuitry and are painfully aware of the dangers of "test lights" in these situations, please realize that there are still tens of thousands of old tractors, trailers, trucks and other older vehicles whose electrical systems can be quite satisfactorily diagnosed with a 6/12v test light.
Us old geezers won't try to fix those newfangled cars if you will stay away from our old iron. Deal?
Brian_B_
North Central, AR
Love it! My 56 is stock (replaced wiring harness of course), but no fancy sensitive anything. I think the whole truck has two fuses...maybe. I have a simple probe light that works well for what I have ever needed on it. :lol_hitti
ra42mario
work on cars all day, everyday. I never needed no stinkin power probe to fix anything. They are just desert, the main course is still test lights and DMMs.
I have a old generic test light. Not sure what brand, but the cord is long, coiled, and it gets bright where it is suppose to.
87FoRunner
Memphissippi
I install a lot of aftermarket off road (think KC) lights and use a generic HF test light most of the time to just assure my wiring is correct. (relay and switch)
Am I a hack? I have a Matco MDTECH for fancy use.
wreckerman5357
Get yourself a Power Probe. I don't have one but I have used them and I will be buying one in the near future.
Carguy99
Warrenville IL
Bah!
Agree^
depends on what you're testing. Im not going to use a scope to test a fuse. If you know what you're doing its just another bullet in the gun.
xj31
Test lights have there place. I use one mostly for a quick check of fuses. Fluke 88 is what I mostly use but even meters have their limitations. I have seen guys get burned. A DVOM can get you in trouble if you just check for voltage. For example, you might have 12 volts when checked with a meter, but not enough current can flow due to corrosion. I have seen wires that are so green and corroded, with only 1 or 2 strands left and you will still have 12 volts. In a situation like that, a test light might better tell the story, but not an led test light. Actually voltage drop testing is the best method in a lot of cases, but thats for another discussion.
Bottom line, all tools have their uses. It's the guy deciding which one is the right one that makes a difference.
Heavy Metal Doctor
Mason Dixon Line
Like some other have stated similarly - the test light has it's place and does not make the owner a hack.....I use mine more often than a meter....but then 90% of my electrical work is tracing out faults in 12volt circuits involved in controls of hydraulic systems on equipment - plain old test light is plenty good enough.....and the SO lights that I have had only ever needed to be replaced when I lost one.
4x4gearhead
New Hampshire
Get a voltage meter, a test light wont actually tell you how much power you have, just because it lights up doesnt mean everything. I was taught to toss your test light and actually measure voltage.
pmohr
Maryville, TN
Measuring voltage is perfectly fine, until you deal with corroded wires or poor terminal contacts. Your meter isn't loading the circuit, and you may very well show 12v. Under load, however, you can have a severe voltage drop and have almost no usable power on that circuit.
In that case, a test light is actually superior to a multimeter, due to the load placed on the circuit. A set of loadpro leads for your meter will do the same job.
Test light, DVOM, scope, PP3, they're all different tools for different uses. None of them reigns supreme for all manner of testing, they each have their place. Just like the DVOM/test light example above, you wouldn't be using your multimeter to test audio output from a radio, would you? You can actually listen to the audio with a PP3. Just as well, you wouldn't be using your PP3 to check the resistance on a crank sensor, you'd use your DVOM. You wouldn't use a PP3 to watch a sensor waveform, you'd use the scope for that.
tl;dr: Using a test light makes you just about as much of a hack as does using a DVOM or a labscope. Just like anything else, different electrical diag tools all have different uses and capabilities.
franzdom
NC
Does a test light offer anything the PP3 doesn't? I really want to learn a lot more about the PP3, all feedback is appreciated.
e-tek
Saskatoon, SK
Where is the best place to get Power Probe 3? That looks great!
Go to the PP# Website - Also Google PP3 reviews. It's all there.
....but - if that's you in your av pic, I'm not sure you should be playing with electicity! :lol_hitti
Brownsfan
Cleveland Ohio
Thats why I have this. Watch the video and how it helps with this exact situation. I do not have a "regular" test light because I am mostly working on sensitive sircuits and newer vehicles. The toolI linked is also great for checking fuses. http://www.hickok-inc.com/catalog/products/76600_voltpro.html
pmohr
Maryville, TN
Yes. Again, a test light will show you an indication of any voltage drop within a circuit (assuming you get one with an actual bulb that draws a decent amount of current, not one of the 'computer safe' LEDs). A PP3 will just show you unloaded circuit voltage the same as a multimeter.
richfinn
Leeds, Yorkshire, England
The key points of the PP3 for me are.
1. Built in volt meter (it will record min/max voltages)
2. The ability to supply power or ground to test a circuit
3. No looking for a good ground just hook it to battery terminals
3. extension cable (great for trailers/caravans/trucks)
4. you can replace the spike with any 4mm accessory
5. Built in twin LED flashlight (cheaper than batteries)
6. Its safe to use on modern vehicles (if you use it correctly)
I get my Power Probe stuff off the local Snap On truck, but you could probably save a few quid if you shop around.
I dont do shopping :thumbup:
richfinn
PP3 shows volt drop same as any other voltmeter does.
a test light has no advantage unless you are so skilled that you can estimate available voltage on the brightness of a bulb.
:lol_hitti
pmohr
Maryville, TN
:lol_hitti
A voltmeter will NOT show a voltage drop under load unless you put a load inline, test while the component is powered up, or use the loadpro test leads. The point here is testing a circuit that does not currently have a load on it.
The test light has the advantage of showing you there's a voltage drop under load. I never said it would tell you what the exact voltage is, but it's an indication that you have a problem. The exact available voltage is irrelevant; once you know you have a voltage drop issue, it needs to be fixed regardless of how much voltage is present.
richfinn
Yeah, I know how to volt drop circuits and use ohms law, thanks
What I disagree with, is you stating it cant be done with a PP3 and that its better to guess how bright the bulb in an old test light is.
That bit is horsesh*t :)
pmohr
Maryville, TN
Do tell, how would you do it with a PP3, without adding a load?
richfinn
Have you been on a load-pro training course or something?
You have always had to load a circuit to volt drop it, its nothing new. You just turn on the circuit or load it with a halogen bulb or use your $100 test leads:lol_hitti.
Its not rocket science
In fact what they have taught you is factually incorrect, If you have an open wire/fuse you dont have to load it and volt dropping will still find it
Milton Shaw
The PowerProbe is great for working on boats, etc that don't have metal frame that everything is bolted to. You can check ground and hot at ease and follow the problems out. I have both PP2 and test light, for checking fuses only I grab the test light. This is assuming you are talking about car/truck/boat electrical stuff not 120/240 home/building voltages. For them a fluke vom meter with volt alert is the best you can get. They are sensitive enough on volt alert to check and follow wires from wall switch to ceiling light etc. Very good tool.
pmohr
Maryville, TN
No, I don't even have a set of them. They just seem to be the easiest and cleanest way to do it, if you're going to use a DVOM. I'd rather use a test light. And FWIW, they're only about half that cost on Amazon.
I don't know who you think 'they' are, but 'they' haven't taught me anything. We're not talking about opens, we're talking about poor connections that don't allow for any decent amount of current flow.
That's exactly it, you have to load the circuit; you were talking as if you could somehow do a voltage drop test on an unloaded circuit. I'm simply saying that the test light is the quicker and easier of the two, if you're trying to voltage drop a circuit. No trying to energize whatever component is on the circuit, or rigging up another load like a bulb (if you're going to do that much, then why not just use a test light? Unless for some reason you're interested in exactly what the available voltage is).
No, it doesn't show you what voltage there is, but almost every corrosion or poor contact issue I've had that's been found through voltage drop testing, it's quite a noticeable difference in light output between good and bad.
Regardless, to each their own. My methods have always worked fine for me, and apparently yours for you.
transittech
My test light started out as a $3 HF unit, and I put a automotive bulb holder in it and a much better wire and clip. Works great.
