What is a good test light to use?
GTA Matt
Zebulon, NC
I just test drove snap ons new multi probe...not really impressed for the money. All the sub menus make it clumsy to navigate. The load testing feature is definitely not a replacement for the load pro. It just says good connection or check connection. No numbers, I like numbers. The power and ground switches aren't in an ergonomic location either, even if the videos claim they are. I didn't buy it, and even with the few additional features, it's not worth it over a pp3 or 4 imo.
j-guenth
Surprise, AZ
I guess I am just a "HACK". I used my test light for over 45 years and I am still using it today!!!
I like the Snap-On test light. I see they now have an LED version.
Go with the Snap-On, I've had mine for 30 years now.
bubinga
Guys have said above, and in shop's I worked in, That sometimes a test light is better, as the bulb puts some load on the circuit.
Now, I'm wondering if the LED would put a load on the circuit as well?
wasabiboys
got an ancient test light from radioshack I use every once in a while. works fine
GTA Matt
Zebulon, NC
Just say no to led test lights. Sure, they can serve a purpose in a low current circuit, but if it's your primary light, it could lead you down the wrong path.
thegroundpounder99
Balm Fl
Post #60.. I posted a YouTube video about it...
Power probes don't ruin computers. People that don't know what they are doing is what ruins computers. I rarely use the power toggle switch on mine. I like it for the instant measurement feature and the fact that I don't have to waist time finding a suitable ground like I would using a test light. Especially doing interior troubleshooting. Being able to put ground and power to what I need is just a bonus. In capable hands it's an awesome tool.
Sent from my Nexus 6P using Tapatalk
I forum through my phone so I thought that was a ad lol. I am thinking about trying that just for the fact the screen is better placed IMO. I have a PP3 I never use, I usually just roll with test light and multimeter.
1949 caddyman
Arizona
I always test the operation of a test light ( make sure it is working before you go in the wrong direction with diagnostics )
anndel
Hawaii, USA
I just got done repairing my 93 Yota pickup using a test light and multimeter. I was testing the solenoids, power cables and sensors. All that time I forgot I had a PP4.
Mastermind
Ypsilanti, MI
I have several, sand a pink pp3. My favorite test light is a mountain or atd or I'm sure 20 others sell the same one, with a gm dome light bulb. Decent little load, bright enough to see, even if under/over where I am. My pp3 is used more often than any of my test lights, but they all have their place.
rhandwor
I have a couple of Mac I've had for for over 30 years one normal and one computer safe.
woody6904
NW Ohio
Every test light I have has a sharp enough point to pierce wires. Doesn't mean you have to. Even my Fluke meter has wire piercing tips you can swap to.
Sent from my SM-G900P using Tapatalk
CafeTools
Yes
i agree, I dont like piercing them especially if they get some weather.
GTA Matt
Zebulon, NC
Yeah, that's what I was getting at. It really bothers me that it's marketed to pierce wires. I literally just got done fixing a fuel pump harness today that some idiot stabbed to death. It's usually a few years down the road before the green growth sets in.
johninct
I am wondering if a LED test light with a volt meter wouldn't put enough of a load on a circuit , could you just put a 12v tail light bulb in series with it?
dopod
Northern Michigan
Mr Snappy didn't have one on the truck. He had gotten one and gave it to someone else for test and feedback. Based on your post, doesn't sound too promising. I am a numbers person as well!
You would put it in parallel with the volt meter, and that would work.
Rarified27
Between PA and NJ
This thread is motivating me to get a new one.
My current one is a no name with a coiled cord which I don't enjoy getting caught on things or wanting to pull out of my hand when I stretch it.
The OTC 3634 is my next one.
crewchief888
NW indiana
ive seen the corrosion start within a few weeks...
a lot of our equipment is run in fertilizer and salt, and never gets cleaned
:beer:
thatguysb
Anyone ever made a good wire piercing tool?
i have a power probe 3, rarely use it unless its a serious problem in a circuit. For chasing down blown fuses and the occasional problems, my cheapo testlight is my go to. Power probe is so odd to wrap back up into the case.
6PTsocket
I just looked it up. The OTC test light uses a bulb that looks like a glass fuse and pulls 150 ma off a 12 volt battery. Whether that is enough to simulate a low voltage situation caused by bad connections would depend on how much current the load in that circuit is supposed to draw.
FigureItOut
Bentonville AR
Get the extension, then shorten the built-in cable to about 6 feet. It's a lot more convenient to use. 6 feet is usually enough, and you have the extension for when you need full length.
Sent from my SAMSUNG-SM-G930AZ using Tapatalk
anndel
Hawaii, USA
I have 3 Snap-ons.
1. Old incandescent bulb type bought in 1986 and it still works.
2. Snap-on LED
3. Snap-on LED with digital voltage display.
Those are called incandescent "festoon" bulbs. The typically draw about 250 ma.
Over 90% of all automotive computer circuits turn the device on via the ground side (ie. the device is feed 5V/12V through one wire and the computer provides the ground through another to turn it on).
So there is 2 things to check at the connector of the "device under test". Is there power on the power wire and is the computer switching the other wire. To see if the computer is capable of turning the device on, use your test light between these 2 wires.
Excellent point ! This is a case where you need a light that will draw more current. Depending on what the device is, you might need a 1A, 2A or even 5A test light. You might be able to find a festoon that will draw 1A (so it would be about 10-15 ohms) but for more, smart mechanics grab a couple of stop/turn/tail light sockets out of a junk car. The 1157 is a dual element bulb which draws about 2A. If you put two bulbs in parallel, the would draw 4 A.
You had better have a good idea what the device should draw before sticking a 4A load on a computer circuit !
It is always hard to get a "good ground" for your test light especially when working under a car. Some people actually take a pair of cheap (HF) locking pliers and screw/rivet the end of their test light cable to the pliers. Not going to fall off.
vssjim
McLean Va.
The old standard one from S and G Toolaid works good has a big clamp and choose a bulb for load desired as many will fit
