Cable cutters?
shoturtle
Frankfurt AM
PS greenlee also has one made in asia, it is a bit cheaper. The HD carries that one also in the electrical section.
rlitman
Long Island
If money is no object:
Pell Hydrashear. I just traded in one of these at a pawn shop for my wife's Ipad2.
reptilezs
Their common one is for copper not for steel braid. They do make one for steel braid but it is buried in their catalog near the back and looks uber expensive.
mine are for wire rope/braid. not diagonal cutters
2manytoyz
Central FL
At work, I use a Nicopress tool to shear stainless braided cable. Cuts it cleanly and quickly. Very important since the ends of the cable have to fit into a swage.
At home, I use either a Dremel with a cut-off wheel, or the 18V Dewalt grinder with a cut-off wheel.
As someone else said, if you're going to cut it with a wheel, either use electrical tape, or even a piece of heatshrink to prevent the ends from bird caging.
While this method works, the Nicopress does a better job.
jetmech09
Cold chisel and a vise. Wrap it in tape. I use masking tape because I always have some around.
2oolhound
BC Canada
We used these guillotine cutters you drove with a sledge hammer when I was logging. They cut different sizes. The blades are replaceable. If you hit it hard enough there was very little fraying of the wires. Great for out in the bush where there was no electricity.
To prevent the end from splaying out you would put a whipping on the ends before cutting which was a tight wrap of light tie wire you wound 10 or 15 times around the cable and twisted the ends together so it was on real tight. There are a number of different methods used to tie whippings of different styles.
w1im
Western MA
How about a cutting torch? I've cut small diameter cable a few times with one and it seems to do a decent job.
An added benefit is that it melts the strands together just like fusing a synthetic rope. No more fraying issues.
rkevins
Central Arkansas
Felco wire rope cutters are the best. They're made in Switzerland.
http://www.felcostore.com/wirecablecutters
I agree on the felco, we have a pair that is over 20 years old and has cut a lot of cable, you can get cheeper ones, arm makes a good one. I have cut 3/16 with the felco style, but if you are going to cut a lot of 3/16 it will dull them, good ss cable is a little harder.
when I worked in the poultry and livestock equipment buisness we used a lot of ss cable in hog farms, if you make a good cut with sharp cutters the cable will normaly not unravel if it does just retwist it.
skruft
I have an HKP cutter that is made to cut wire rope and ACSR up to 1/2". It's an import and not that expensive.
I have one of those! the "Impacto Cable Cutter!"
Works OK on larger cable (> 1/4"? ) not so hot on small stuff.
fast one
MD
Could you tape the end up with a wrap of electric tape and cut it with bolt cutters? I do it with 1/4, 5/16, 7/16 all the time with no problems.
