Stupid question...radiator fans...ac or dc input?
pipsters
USA
Just curious if radiator fans are AC or DC powered? I assume 12v DC but just wanted to double check...
Rico.
England
If we are talking about motor vehicles then they are all 12v DC
I have never heard of any vehicle that uses a low voltage AC for anything.
Ken81590
I could understand someone's confusion to this, because the generator is refered to as an "alternator", it throws people off.
Cryptic1911
Willimantic, CT
Well, actually a car alternator creates AC (alternating current), but it is run through a series of diodes that create a bridge rectifier to convert to DC current. It takes half of the sine wave and flips it so that there is a semi constant DC current, and then it is run through a regulator to keep it at a steady output to charge your battery
38Chevy454
Cincinnati, OH
X2, an alternator does produce alternating current. But it is convertted to direct current by the diodes as stated, so the output is perceived as DC.
Radiator fans on a vehicle will be 12 volts DC. Because of this you can make the motor run in reverse, so make sure your blades are blowing the correct rotation. Most OEM fans have a shaped plug to prevent hooking up wrong.
Alchymist
Central PA
Nice diagram, but you only got part of it. Most Alternators are 3 phase.
magova1104
USA
Flatintoone
West Bend, WI
I haven't done any looking myself, but what about variable-speed, brushless radiator fans? When I first saw them in OEMs about 10 years ago, I remember a lot about them being whole new animals. I would guess that they were DC, but I know little enough about the black arts that I'm wondering if they could be AC.
richfinn
Leeds, Yorkshire, England
Most stuff like this in my experience has a stable DC supply and the ground is pulse width modulated (fast on/off digital signal which is variable depending on conditions and sensor inputs) by a control module to alter speed.
Morrisman
Angeles City, Philippines
A variable speed motor would be DC. AC motors are fixed speed.
I looked into this when I was running an electric water pump on a hot rod, and they do make a control module that varies the speed of the pump to regulate the engines temperature, but it cost more than the pump itself. This could also be used on a cooling fan for a guess.
Alchymist
Central PA
AC motor speed can be varied by varying the frequency. Newer motors designed for such application have a wide range of speed control with a VFD.
Danglerb
SoCal
If it goes in a car its 99.999% DC at least to the control module.
PWM, pulse width modulation controllers turn the DC on and off very rapidly, and control the motor by varying the on/off time just like fuel injectors are turned on and off to regulate the amount of fuel flowing through them.
Simple relay controllers turn the DC on and off VERY slowly (infrequently), like on for a minute, off for a minute or two.
Vvmvbb
CT
As long as we're talking about this and educating some, after the diodes is not really DC. It's rectified, ie single polarity, but still has a lot of high frequency oscillation on it. It must filtered for it to be DC. We often filter with capacitors or with the battery on vehicles.
Danglerb
SoCal
Outside of theory nothing is DC, its very very very very very low frequency, due to at some point going from off to on etc.
In practice headlights don't care, and voltage in a car is loaded with noise, enough that many devices plugged into a cigarette lighter can detect rpm, diode conditions, etc.
71flh
Direct current (DC) means current flows in one direction. There's no theory to worry about.
Alternating current (AC) means current flows back and forth.
Therefore, rectified AC is absolutely DC, but not nice and clean like a battery would produce. You can have inductance with pulsating DC, but its still DC.
If you look at the pic by Cryptic above, he has a sine wave AC cycle where Voltage is + and - half the time. Current is flowing one way half the time (above zero), and the other the other (below zero) half of the time.
In the same pic he has the rectified pulsating DC drawing, the voltage (and therefore current) never go below zero, so there is zero AC component.
Again, there can be inductance in a DC circuit. Think of the operation of an ignition using points as the simplest example. Points close, Voltage (magnetic field) increases across the coil (step up transformer), points open, voltage (magnetic field) drops inducing a large voltage on the secondary which leaps across the spark plug gap.
The last paragraph is an example of coercing DC to make AC oriented effects happen, but AC and DC are two different things. The output of an alternator before the rectifier is AC; after the regulator, its DC--pulsating, but still DC.
redwrench60
East Tennessee
Most speed sensors send an AC voltage signal (in millivolts) and oxygen sensors generate an AC voltage (also in millivolts) :beer:
Rico.
England
I love it when I learn something new in a given day.
Although to be honest when I said I didn't know of any vehicle
that used low voltage AC for anything, I didn't mean that low. :D
71flh
Yep, that's interesting. What happens when rain, rust, dirt, etc. get in there and jack with that mV input?
Scary....
redwrench60
East Tennessee
Scary....
Well, usually an ABS or check engine light but nothing dangerous. Sometimes improper operation of the affected component. For the most part the weather pack seals on connectors do a pretty good job of sealing out contaminants but nothings perfect.
Flatintoone
West Bend, WI
Is an oxygen sensor's output actually an AC voltage? Its output varies, but isn't that because the engine controller is constantly driving the mixture alternately rich and lean?
Stick
Alaska
Usually O2 sensors produce output of 0-1VDC.
The only AC voltage that is commonly generated on a vehicle is the internal AC in the alternator, or output from reluctance based sensors (which then is converted to a DC signal at some point for the PCM to use).
Vvmvbb
CT
No. DC means zero frequency. A rectified AC waveform has a DC component and a large AC component on top of it. In automotive electronics the distinction rarely matters and you can think of it as noisy DC. But to pro EEs such as myself, the distinction becomes rather important.
Alchymist
Central PA
^^^^ What he said ^^^
Power supplies from rectified AC have the same problem, and requires filters to remove the AC portion. It's one of the causes of the "hum" you hear in the background of a stereo system.
Cryptic1911
Willimantic, CT
lol, look what I started!
I probably should have found another image online that also showed filtered dc output instead of just the rectified output for less confusion, but the pickins were slim
O2 sensors are DC voltage
A/F sensors can be in mA though
Agreed the O2 is DC. you can actually make a direct reading of the O2 sensor and get and idea of the Air/fuel mixture, (which is it indirectly measuring by converting the temperature of the exhaust to a variable DC voltage, albeit a very low voltage.)
Total range if the O2 is near 0 to about 1.1 V or 1100 mv (millivolts or thousandths of a volt), after it has fully warmed up. (takes a minute to a few minutes) and how to convert that to the A/F mix is in the chart below:
I had a DVM connected into my minuscule 4X4 for about a year trying to find an intermittent AF problem that was hitting it hard for top HP, made the difference between hitting the front turbulence of a semi truck and getting kicked back when attempting to pass, and just breezing by in the same pass, and it turned out to be one of the odd ball smog control valves that adjusted the carb.
A lot of Carb tuning info can be found HERE : and looking for the "Carburetor Tuning the Scientific Way: " link down the page.
A lot of Carb tuning info can be found here: and looking for the "Carburetor Tuning the Scientific Way: " link down the page. This guy also sells a nifty little recovery system for oil bottle residue.
Vvmvbb
CT
Ok I'll let that slide. Rats. I can't. I hate myself. O2 sensor signal will have an AC component oscillating between rich and lean. From the excellent, must read Bosch Fuel Injection & Engine Managment by Charles Probst :
Stick
Alaska
That's still a DC signal. ;)
The voltage varies between 0v and 1v, but it never goes below 0v. Just because the voltage changes, doesn't mean that it has any AC "component" to the signal.
Alchymist
Central PA
Not really .... any electronics tech will tell you it's an AC signal floating on a DC level. Run it through an RC circuit and it's pure AC.
w1im
Western MA
I'm not an EE by any means, but surely you wouldn't class any DC signal with varying voltage as AC?
I am an EE and Alchymist is right. It is an AC signal with a DC offset. It can also be considered an AC and DC signal that have been combined.
Remember, voltage is all relative. Compared to a different reference, the signal in Vvmvbb's post could be above and below that reference. You can also feed a signal like that into one kind of circuit and get only the DC part of it and a different circuit and only get the AC part of it.
I don't know what an oxygen sensor has inside it, but you would see a similar waveform across the terminals of a DC motor when the shaft is spun by an external source. To get back to true DC you would need to filter out the AC component.
It's classed as DC with an AC component. Some of you guys are making this harder than it needs to be. :D
The bottom line is that you can measure it with a DC DVM in the millivolt range, and get useful info on it...
Lets face it, most current almost anywhere not strictly regulated is pretty "dirty" stuff viewed at the "theoretical" levels. What matters is what you can do with it...
w1im
Western MA
That DVM when set to DC should give you the DC component and when set to AC should give you the AC component. Always good to check both when looking at a signal with a DVM and not an oscilloscope.
jrlp
Laredo, Texas
Good dvm can show both ac+ dc at the same time. My fluke 189 does.
Sent from my Galaxy Nexus using Tapatalk 2
Vvmvbb
CT
Yeah verifying the presence of the AC component should be a very good thing to do when troubleshooting O2 (lamda) control, heh? It would tell you that the the control loop is at least trying to work (out of open-loop mode and making fuel adjustments). Next time I change out an O2 sensor I'll grab a scope trace before and after for kicks.
DC coupled probe, of course ;-).
