Rodhotz
Rear end from '73-up isn't a bolt-in.
'60-'72 is the trailing arm/coil spring rear end with a panhard bar locator.
'73-up is leaf spring.
I THINK, but am not sure, you can simply swap the axles and the brake drums to the early housings. (except '60-'63)
-Brad
True Brad, but with a few hours and a torch and welder the original brackets can be put on the late model rear. much easier than doing a frame swap. My 64 like his is a heavy duty 3/4 ton and i have been measuring up a 74 1 ton front i have for a possible swap. got a dually rear i may play with also. everybody wants me to put 1/2 ton running gear under it but it is my daily and i plan to do a lot of towing with it since i sold my dodge diesel. I have a 12 valve laying around, i was kicking the idea around of putting it in the truck, but i think i am going to use it in my 36 dodge brothers duce and a half car hauler i am going to build.
