Williams S-52 Ratchet
u118224
Northern MI
I have an old Williams S-52 and I need the screw that retains the forward/reverse selector. Does anyone a) have one, or b) know the screw size so I buy one? I think it's a slotted head rather than Phillips.
U
u118224
Northern MI
FYI, my ratchet looks like this.
magova1104
USA
I do have ALL kind of screws. (1000000's)(fine thread,coarse,stainless,vintage,NOS,etc. but I don't know the S-52, If someone knows the type/size, maybe I have it, I will ship it to you. :thumbup:
U
u118224
Northern MI
I spoke with Williams (Snap On) and they couldn't give me the screw size. Thank you for the replies. If anyone has one of these ratchets with the screw and can give me the size, etc., I'd appreciate it.
TwoInch
NW INDIANA
Mohawk Dave
SoCal
Old thread I know, but for future lookers, the screw is 8-32. Little less than 3/8" long. I had to cut mine down today...mine was lost as well, and I bought a hex one from Ace Hardware. I also used a proper sized metric washer that fit on top of the selector switch as well, as it was MIA.
KT_NorCal
Hey, not to thread-jack this discussion too much, but I've got a J.H. Williams H-50 3/4" ratchet that has the "ring nut" as described by a previous poster (attached a pic with a Williams torque wrench that has a similar set up) and also has some sort of a "drain plug" looking thing off one side below the ratchet head.
Does anyone know how to take that nut off or what kind of a wrench to use to do it? Sounds silly, but I'm not even sure what to google to look for something.
The wrench is in good condition, but I have a suspicion that it has never been serviced, so I want to take it apart and clean/grease it properly, but Can't do that until I figure out how to get it apart...
Thanks for any ideas/help!
reptilezs
a pin spanner might work. check with a bicycle mechanic, show them the lock ring and they will know what you are talking about
KT_NorCal
Ahhh, bicycle shop. Didn't even think about that. Thanks for the tip. At least I have a name to start searching off of. Never heard of a pin spanner before, but will give it a shot.
Strange that the side screw would only access the pawl. I would think you would be equally likely to strip that or the interior (big) gear....
Thanks!
KT_NorCal
Turns out HF no longer sells the adjustable pin wrench... back to square 1.
Going to try ebay for something that will hopefully fit and is robust enough to apply enough torque to get the faceplate off without damaging it...
SCscoutguy
South Carolina
KT_NorCal
Hmmm, I rigged up a ghetto version of a pin wrench, but the "ring nut" wouldn't budge. Couldn't get a enough torque applied to it with the home made version.
It did just occur to me that it was possibly reverse threaded though... was yours standard thread?
The manager at the local HF told me that they no longer stock it in store and that she wasn't seeing it replenished in the warehouse. It is on their website though so I may give it a shot and see if they actually send it.
Thx!
