920kip
Pool and shop look great. The tiled pool deck is a new design element that you failed to mention though. LOL
Awesome progress. Everything is getting ready for the party!
That will be a lot of concrete to pour. Be very grateful for hiring it out.
SL
Great execution on the rebuild, love the fit and finish on the staining and race deck. Be sure and include me on the list for the 1st Annual SpeedinLemon Texas Hold'em Tournament. When you have a casino that nice, I am sure the line for attendees will be long.
This whole project is turning out fantastic!!
The place is really coming together and looking nice. I'm looking forward to your next build when you realize that current shop is too nice to do any dirty work in.![]()
The woodwork is looking really good and the whole garage is coming along nicely.
great shop man...after reading down tru the tread it seems to have worked out better for you that you had a fire as look at the changes gone into it now.....id say that was a scarey accident in your truck with all family??? glad to hear nobody was hurtits great to have the little man help
The accident was scary and I AM calling that night a blessing! With 8 of us in there, it could have turned out much differently! God was on our side that night for sure. The little guy is a lot of fun to have around. He's my most dependable helper. The whole family has pitched in, but he's always the first to volunteer to "Go work in Daddy's shop!".
Great work, Lemon...just read the rebuild and it has come along great. Oily rags burnt down my father's high school shop in the mid 60's here in Portland, before that they were never aware they would "self ignite" essentially. Keep it going strong!
I still standby "too nice to work in" but it looks so freaking nice.![]()
I had an issue with tape pulling paint off a while back. I basically had to pull it off before the paint was dry.
Nice work.. I also ran into that tape issue once. Then found out that they make several kinds of the blue tape. They come in "days" of sticky.. I found some that said it was "1 day" stick. This was after it was on the glossy hardwood floor, and it ripped up the clear coat. Doah!!
I'd like to say I have 'The Fix' for your paint stripe problem; it may indeed be a 'tape left on too long' situation, but I don't like the pic of how the light green is lifting. It may be the quality/brand of the field color paint itself that is the root problem. What specific primer and finish coat(s) did you use? If you can take the time, prime a piece of scrap wall material, let it dry as per the label, and lay a coat of red on top of it; does it cover in one coat, or does it show as pinkish? If the test piece shows up red (or less pink than your single coat on the wall), I would then suspect the light green wall color is interacting with the red's volatiles, and is causing 'bleed-through'. If that is the case, I would then suggest you re-prime/seal the field color in the area you wish to apply the stripe. Like any paint job, it's 90% preparation and 10% application, unfortunately we sometimes think we've properly prepped and are sadly mistaken after the application. Good luck in finding a fix that you'll be happy to live with!
Oh, you've probably heard about the stripping trick with the less expensive tape. To prevent a ragged line edge caused by capillary action under the tape edge, lay out your tape, then paint over the edge of the tape (edge towards the stripe) with the field color of your walls. The field color is what gets sucked up by capillary action; after it dries you can apply your stripe color without getting that ragged edge. Again, you want to remove the tape as soon as you complete a section and not wait until you do the entire room. Also, you want to pull the tape not out from the wall, but back along its path and just slightly angled away from the freshly laid paint to avoid lifting of the finish coat. For a little insurance, if the tape sat a while, I would lightly score the tape edge with a single-edge razor blade, or a very sharp penknife, prior to removing the tape to avoid any lifting/tearing of the finish coat.
My shop is still more pinker than your shop my friend! Love the work you you have done, looks great.
Shaun
lol
.. The pool looks great, you are about a year ahead of me on this portion of my garage build. Couple of question??? what is the lf' of the pool? I really like the size of it. Also how did they attach the wood post for the pergola? Looking great and yes fix that tractor tire.
That red is just a pain...it may be the brand/type of paint, but seems like I've heard stories on red paint having a hard time covering especially the lighter colors.
Still a few things to finish up and I may need an engineering degree to run this thing:
View media item 21960
Looks Great!!! Gives me some things to think about when we start designing our pool. Congrats on the progress so far.
love the setup in your garage,, i have a similar set up im thinking of doing a 16 foot door in the middle also, do you love your or would go back and put two 10 footers in the front...
