Steve Bryant's Blackhawk Jack Thread
Steve Bryant
Wichita, KS
Guys, that looks like a good jack!
I still have to sand blast and paint mine plus I plan to work on the rear casters some more. Otherwise, it is still working very well, thanks to all of you who have paitently helped me.
I'm now working on some major refurbishing in my 1991 Airstream travel trailer. Here are a couple of threads, if you want to take a look http://www.airforums.com/forums/f427/cleaning-and-refurbishing-my-suburban-nt-35k-furnace-86137.html and http://www.airforums.com/forums/f36/leaks-and-floor-rot-in-91-34-limited-85517.html.
All my best,
Steve
semis57
thanks I will look into it. Kind of torn because this is a complete working jack and I'm really just looking for a parts donor...
2002 f250
hi
wow glad i found this site i a s4 that needs to be rebuilt .i have no clue what your talking about with v packing and overload valves but i cant seing it being more then a couple of oil seals and o rings
Hiball
Missery
hi
Your in for a surprise then....
Steve Bryant
Wichita, KS
2002 F250,
It's as Hiball said above, you are in for a surprise. For something that may look fairly simple on the outside, there's a lot of parts and technology on the inside. It's not rocket science...but it's more than a couple of seals and O rings. In fact, this jack predates O ring technology and it will probably take a fair amount of work to get it to work properly.
Best of luck to you sir!
Willy-C
Hooksett, NH
I agree Hiball and Steve.....
Jumping into a project like an S4 rebuild and thinking it is cake will only end up in a scrap heap if precautions and/or pro help is not used
Best of Luck f250
2002 f250
dont know of any jack rebuild shop up this way never heard of anyone ever rebiulding one so iam on me own ,how did you remove the pump pluger #16 on the part list i dont see anything that holds it in
Hiball
Missery
You must remove Handle/#12 so you can pull it out, The only thing holding it in is Tension applied by #23 <--- Compression Nut, squeezing the seals against the OD of #16.
2002 f250
hi
got the piston out .you dont need to remove the #12 part has nothing to do with the piston coming out
Hiball
Missery
hi
I'm away from my schematics currently but im sure #12 was the linkage that connected the handle to the pump ram. I guess theoretically you "don't" have to remove it, just the pin connects the handle to it.
2002 f250
ok yes sorry didnt understand yes i have remove the whole power unit from jack frame sorry about that .now it looks like a special tool is needed to remove the spacer half way in
