Got a williams S-52 finally.... BUT
TwoInch
NW INDIANA
i can not get this bad boy apart....
i have soaked it, punch, chisel, soak, repeat, soak repeat. also modified a 4.5" grinder spanner to fit, same as i did for the B52(which worked) and put some serious *** into it, and twisted/mangled the spanner....
i have it soaking again. the ratchet is in near perfect condition. i would like to get it apart and greased, as its bone dry and clackity same as the B52 i found. the superlube made it 1000% smoother.
im afraid im gunna ****** up the contact points till they are useless, so i have given up for the time being. any ideas? the tool mentioned last time i dont think will handle as much torque as the spanner i twisted up with the ball-peen
:dunno:
u118224
Northern MI
TwoInch, could you measure the slotted screw that holds the selector switch, including thread pitch? I need to replace mine.
BTW, congrats on the acquisition. I used mine last night.
Rickster
SE PA
What are you soaking it in?? I use automatic trans fluid .... works well to unstick stuck stuff.
T
TwoInch
NW INDIANA
T
TwoInch
NW INDIANA
update - well, i have now soaked it twice for extended periods in atf/acetone, and to no avail. i have twisted up two modified spanners. the ratchet it in such nice shape, i can not believe i cant get it apart. im totally stumped
:headscrat
beelsr
NE PA, USA
once upon a time, i made a special wrench for this out of a socket. if you're having this much trouble, the "teeth" would probably shear off on a home-made tool before it opened for you. so save that for the future...
maybe the last guy in there loctited it? but the acetone would have hit that if it could reach...
maybe time to consider some heat. a mini-ductor would be controlled heat without flame.
maybe you could make a HD spanner out of large flat-tip screwdriver bits and get super-serious *** behind it?
or just soak it for another week. you've lived years without one, what's another week?
T
TwoInch
NW INDIANA
using a socket and getting all four contacts hooked up might be worth a shot...
i was thinking heat already, just pondering on what would be the method of choice without really cooking the finish.
i was also thinking it might be red locktited, thats quite a bit of surface area for it to grab, and i am at a disadvantage with the little grooves being of no leverage advantage as they are inboard of the threads.
also thinking of ways to force the grease in pneumatically or with some sort of pressure and saying **** that nut.... hmmmmmmm...
T
TwoInch
NW INDIANA
im going to try cutting a cr-v impact socket to fit all four slots, and if that doesnt work. im gonna pack the grease in manually like a bearing. and if that dont do it, im selling it on ebay and saying better luck next time.... :lol_hitti
John316
Anywhere, USA
You could space 2 screwdriver bit tips (not the real short ones) or similar pointing up in a vice so that they meet two of the ring slots. cranked very tight.
Rickster
SE PA
I have a couple of extras available....
Before getting anything really flammable inside, try getting it in a oven at about 400 F or so. At least with an oven you have some control over the temps...
T
TwoInch
NW INDIANA
good thinking. thats an idea too. although they are soft, maybe impact grade or something. the spanner im using was pretty tough steel, and it mangled and eventually partially sheared one pin.
T
TwoInch
NW INDIANA
what are you looking to get for one? and have you gotten any of them apart? :lol_hitti
the one i have is most similar to the top one in your pic, and has a B stamp next to the PATD stamp. it is also in like new condition, the best i have seen, with only very small imperfections in the knurling in a couple spots. the ratchet is gorgeous... again i can not believe it is giving me this much grief..
sselander
CT
Mike007
A friend of mine recently acquired 12 like new S-52's for free. He gave me one and gave the rest away. I know this doesn't help you, but it's a sweet tool. :thumbup:
T
TwoInch
NW INDIANA
member J.A.F.E has a great thread on the internals:
Willaims Superratchet Disassembled
http://www.garagejournal.com/forum/showthread.php?t=36498
I modified an HF pin wrench to get mine apart
http://www.harborfreight.com/adjustable-pin-wrench-36554.html
see post #5 in this thread..... :lol_hitti
and the grinder wrench is what i have been trying, and ruined two of them already. mangled, bent the arms, and sheared the pin off. when i say its stuck, i mean its really stuck :thumbup:
i did get my B-52 apart with a modified 4" grinder wrench tho, worked like a charm.
neonnblack
Reno, NV
There is a reason it looks new, someone else couldnt get it apart and tossed it in a drawer.
T
TwoInch
NW INDIANA
if someone tried getting this one apart, they didnt try very hard. the slots were in perfect conditions before i got to it. there was zero sign of any tool trying to remove that nut.
that might be the problem. it hasnt been moved since it was put together, probably dry.
T
TwoInch
NW INDIANA
you guys that use the ATF/acetone concoction, i remember reading that the mixture stays in suspension, but the stuff i made up separates within about 45 seconds of mixing it up. i try to keep mixing it every little while, but man, what the hell.... :headscrat
T
TwoInch
NW INDIANA
i am using dexron II-III type atf.
i have also hear that PSF is the original, but have actually heard many more people using ATF.
i tried MMO for 24 hours, before the ATF/acetone mix. supposedly, the ATF mix is better than kroil or any other penetrant out there...
lwlobo
Colorado Springs, CO
If you modify an impact socket to engage the slots, try using the a hand impact to turn the socket. The shock, rotation and downward force of the hammer blow can unstick some really stuck stuff.
I'd heat it in an oven to about 400 degrees like outlaw said, apply kroil or your ATF/Acetone mix and let it cool. Heat it again, apply penetrant, then put your modified socket and impact on and smack it really hard with your BFH. If it moves even a tiny bit, keep whaling on the impact until it spins free. If that doesn't get it off, repeat the process once or twice more. If all this fails, give up and move on with your life.
T
TwoInch
NW INDIANA
update.
well i finally gave up on this one. soaked and soaked and soaked. nothing worked. pretty unreal actually.
anyway, i noticed that when i drained it the last few times, no black gunk was coming out any longer. so i sat for about a a half hour with a palm full of superlube, and packed it like a bearing. not easy going, but packed it a bit, tossed a socket on it and gave it a couple good raps on a block of wood to move some grease down into the mech, and it worked. took a few minutes to get the ratchet cleaned up, but it is smooth as butter now. no screeching and clacking of the mechanism. works as good as it looks now. hopefully it stays that way :beer:
magova1104
USA
Maybe that piece is assembled with loctite? . The only way is to use heat to loosen it, any liquids or solvents can't dissolve the loctite. You can use a small torch.:thumbup:
spongerich
Monroe, NY
The next time you use it, the retaining ring is going to pop off and fall down inside of whatever you're working on.
:lol_hitti
T
TwoInch
NW INDIANA
i didnt want to ruin the finish on the ratchet. it is in great condition. works now, and i was just being stubborn, and didnt want to admit defeat.
ill post a pic of it here in a bit. i should have already :lol_hitti
ajchien
Los Angeles, stuck on the 60 freeway.
I had difficulty opening my B-52. I wound up putting a pair of needle nose pliers clamped into a vise. The pliers were opened so that the tips fit into the locknut slots. Put the ratchet into the slots and worked it back and forth quite a bit. I heard a "crack" during one tightening attempt, and then it proceeded to loosen up just fine after that.
T
TwoInch
NW INDIANA
i mounted different things in my vise, and attempted that same method, and only mangled the slots in the ratchet nut. until everything started camming out. thats when i threw in the towel.
Provincial
Near Salem, OR
When dealing with situations like this applying pressure to hold the tool in the slots is a must. Anything from a c-clamp to a hydraulic press has been used for this. It keeps the tool from camming out. In the old days of replacing field coils in starters and generators they actually had tools to keep the square drive tool engaged with the square recess in the screw.
Hiball
Missery
Obviously Not the Correct tool for the Job, But did you try using a small pin punch to Persuade it?
T
TwoInch
NW INDIANA
i used an 8 or 10" c-clamp, and also rigged the vise in different ways to keep the tooling in the slots, but the damage was done. the c-clamp method is how i ruined the two pin spanners, which worked well, and applied a ton of torque. twisted the legs of the spanner and eventually sheared the pin off one side.€
i didnt give up with out one hell of a fight.
