universal sockets and torque
DHCrocks
Hawaii
I know you lose a bit of torque when using an universal socket but how much? Is there a general guideline for how much more I should apply when using these sockets?
D
DHCrocks
Hawaii
I can feel the joint flexing when you apply pressure and are at an angle so there must be some torque lost at the joint and since it's not in a straight line. Is it so insignificant that it can be ignored?
DavidtheDuke
I thought that u-joints actually increase torque.
Try taking off a really tough fastener with an impact swivel at it's max angle. Usually doing so takes most of the torque from the impact away before it gets to the bolt head. Aka, it doesn't take it off unless you can figure a way to get straight on it.
Charles (in GA)
50 mi south of Atlanta
Same experience here.
I would not use a u-joint or swivel socket for torque unless absolutely straight on. No way of judging or calculating the change in torque.
Charles
krusty the clown
Member Emeritus
niangua, mo
Uncle Buck
Kansas
I always try and avoid flex sockets if at all possible for torqueing applications, I only use one when I have no other choice.
nissan_crawler
Wichita, KS
We use them all the time in aircraft to the specified torque, never had a problem. Any time you add anything to an impact, be it an extension, long socket, etc., you're going to take some of the power away, that's just the nature of it. Hopefully you're drawing your torque wrench up steadily though, and not slamming on it.
garfunkle24
Saskatoon, Canada
During my technical training I was advised by my instructors to add 3% torque for every inch of extention used and 5% for an adapter and 10% for a swivel or u-joint. I'm sure these are rough guidelines, and I don't know what it's based on, but it's what I was told.
GDA
Dallas, Texas
From what I've read, I was under the impression that the specs on torque wrenches were spec'd for a certain point (distance) from the ratchet head based on a true single 90 deg attachment point to the ratchet. So that would be one socket attached and adding an extension would also tend to lower the actual torque applied. I would believe a universal will also impact this direct effort and result in some (albeit minor) level of torque at the fastener.
Charles (in GA)
Cannot say I've ever heard or seen any of this. Even if an extension twists, it is not absorbing the torque, it is still transmitting it to the far end, you can pile on a couple of feet of extensions, but if kept straight and square to the torque wrench, the torque will be the same at the fastener as if there were no extensions. I seem to recall a discussion similar to this a few months ago. Now a swivel, or u-joint, yes, as far as I'm concerned, it "eats" torque if you are at an angle. I suppose I could prove this by using my Craftsman digital inline torque measuring device and a torque wrench and a universal, extensions, etc, and see how much the torque wrench varies from the digital readings when different attachments are used.
Charles
GDA
Dallas, Texas
Charles
I agree that extensions will not impact applied torque if.... they are kept straight and square to the wrench. However, analagous to golf shafts the longer the extension and given level of flex, the overall repeatable accuracy of the applied torque would be the one most impacted. Also known as repeatable shot dispersion.
I am not an engineer so I'm just posting what I understand from reading about the proper use of torque wrenches and application to a similar concept.
Lightning
You can use univeral sockets with torque wrenches if you know the offset angle. You must set your torque wrench to a greater torque if the plane of rotation of the torque wrench head is not parrallel to the bolt head plane of rotation. If you have any offset angle the torque applied to the fasterner will be less than the torque wrench setting so you must adjust for this.
If I remember correctly the impack swival sockets have a 30 degree offset MAX. You need this information to calculate the torque setting for your torque wrench.
I think the equation is
TA = T/cos^
where TA is the applied torque or torque wrench setting
T is the torque applied to the fastener
^ is the offset angle.
So if your wrench is parrallel to the fastener ^ would be zero and if the fastener spec is 100 Nm torque then TA = 100 Nm/cos(0) or 100 Nm which is the same as your torque wrench if you are using a regular socket.
If however, you use a swival socket and the offset angle is 30 then
TA = 100 Nm/cos(30) or 115.47 Nm
If the angle is only 20 then you set your wench to only 106.42 Nm
The greater the offset angle the greater you much increase your torque wrench setting.
Lightning
I would not use the U joint univerals with a torque wrench because they bind. If you must use a universal with a torque wrench use the pinless impact swival from Matco or Craftsman. The pinless design is much better.
Lightning
If you are using a wobble extension, the maximum offset is 16 degrees which means if you do not adjust your torque wrench the fastener will be under torqued by as much as 4%.
nissan_crawler
Wichita, KS
which is the accepted error in a torque wrench. If your torque wrench is accurate, it's not a big deal. Each to their own, though.
D
DHCrocks
Hawaii
the reason I was asking was I had to tighten down some bolts in an aluminum block and because of the tight access I couldn't get a straight shot so I had to go to the universal socket. it was so tight even that could barely fit. I had to use a 10" extension and I'd guess I was about 2"-3" off centerline of the bolt. Very hard situation I had to even use my flex head torque wrench so I know the with all the those things going on the torque value as a little off . Yes it was a good socket, it's a SnapOn and no it didn't bind. If it's only off 4% or so no biggie I guess.
Lightning
There are some fasteners that are very critical and must be stretched precisely so that the tension in the threads is near perfect. Most fasteners are not that critical and only require torque in a certain range and for the most critical , strain and angle guages are often used instead for better accuracy. Fasteners are torqued to spec so that the bolts are stretched enough to increase tension so they do not loosen but not so much to damage the threads. This is why torque wrenches are used but they are less accurate due to friction between the bolt head and washer.
Only use univeral swival sockets with torque wrenches when you must because it does introduce some error that would otherwise not be an issue. It is usually quite small though if the offset angle is not too large, but you can increase the torque setting to compensate.
If you are using wobble extensions with your torque wrench increase the torque setting by about 2 to 3%. It is usually better to under torque slightly than over torque. If you are using impact swival sockets use the maximum 30 degree offset and increase the torque setting by about 14%. This is slightly less than the spec torque but probably close enough.
