I thought that u-joints actually increase torque.
Try taking off a really tough fastener with an impact swivel at it's max angle. Usually doing so takes most of the torque from the impact away before it gets to the bolt head. Aka, it doesn't take it off unless you can figure a way to get straight on it.
if you are talking about tourqing with a tourqe wrench it's insignificant. you do lose some of the power of an impact though.
You sure about that? I thought that it definitely affected torque...
During my technical training I was advised by my instructors to add 3% torque for every inch of extention used and 5% for an adapter and 10% for a swivel or u-joint. I'm sure these are rough guidelines, and I don't know what it's based on, but it's what I was told.
From what I've read, I was under the impression that the specs on torque wrenches were spec'd for a certain point (distance) from the ratchet head based on a true single 90 deg attachment point to the ratchet. So that would be one socket attached and adding an extension would also tend to lower the actual torque applied. I would believe a universal will also impact this direct effort and result in some (albeit minor) level of torque at the fastener.
Cannot say I've ever heard or seen any of this. Even if an extension twists, it is not absorbing the torque, it is still transmitting it to the far end, you can pile on a couple of feet of extensions, but if kept straight and square to the torque wrench, the torque will be the same at the fastener as if there were no extensions.
Charles
I would not use the U joint univerals with a torque wrench because they bind.
If you are using a wobble extension, the maximum offset is 16 degrees which means if you do not adjust your torque wrench the fastener will be under torqued by as much as 4%.
I would not use the U joint universals with a torque wrench because they bind.
Only if you're at one hell of an angle.
