Atomizer - DIY Air Cans
mobiledynamics
Gotham City
Does such a beat exists...
Are there bottles where I can put my own liquids in and put compressed air via the compressor, etc ---- vis a vis diy spray cans.
I've got hand sprayer bottles...just wasn't sure if they had cans where I can pump in compressed air to make my own sprayers.
If I recall, I have seen larger setups that look like insectide sprayers 2-3 gallon sizes that did this
mobiledynamics
Gotham City
Holy Motherload...u guys are genius. Sure shot spray it is.
Got a great spot to order them in bulk. Methinks I want to order a dozen for now...
nate379
Palmer, AK
Harbor Freight has an aluminum one for around $9. I bought one 2-3 years ago and still works great. I have solvent in it and use it all the time.
fxt
picked two of those up last month. they were on clearance.
Fedwrench
Valley of the sun
Sureshots are best thing since a pull top can.:thumbup: Just be careful what you put in them. I have a couple at work for brake clean. The sprayers are rebuildable too.:beer:
srmofo
SW ohio
I believe it has a shrader valve and can be pressurized with a tire air chick.
correct. All the guys at the shop have em for brake clean. they also make great flame throwers:shocking:
surprisingly durable also. They tend to be the first thing that gets thrown when someone gets frustrated. rebuild kits are around $15
socketjockey
Gilbert, Arizona
For large scale degreasing I keep a one gallon pump type yard sprayer full of simple green. Some even have a pivotable atomizer head which is great for engine cleaning.
nate379
Palmer, AK
The sureshot is nice, but at $50-60 for one vs $9 for a Harbor Freight one... hmmm.
Look in the catalog, it's a white can with an eagle on it. I don't know what they call it and can't find it on the web page.
rodm1
The best use I've found for the Sure Shot is filling small gearboxes in those hard to reach places where a funnel just won't fit. If you remove the spray nozzle, those male threads are 3/8 - 24. I added an adapter & 2' clear vinyl hose from there.
Grate idea I've wondered about that but never could figer out how to attach a hose grate idea.:beer:
nate379
Palmer, AK
What Sure Shot are you using that can push gear oil through it??:wtf: I just use a bucket pump for filling diffs and transmissions.
bigjmcconnell
Halifax, PA
Digging up an old thread here...
Anyway, I have the sure shot atomizer. I bought it for bulk brake cleaner. But either I'm using it wrong or it isn't quite what I was hoping for.
I wanted the super powerful shot like a can of areosol brake cleaner. I have the "stream" nozzle on it and even pressured to 135 psi (max for my compressor) it just doesn't have the powerful stream I wanted.
Any suggestions welcome. It will accept 200 psi but I don't have a method of delivering 200 psi.
coldfusion21
portland, oregon
Something is wrong then, and I cringe hearing you pumped it to 135 psi...
I use an old one that's my buddies and at 40-60 psi it's almost too powerful, like shoots ten feet and gets brakleen on everything. I've never filled it anywhere near 100psi.
mobiledynamics
Gotham City
It' the viscosity....
For the intended products I wanted to use it for...I have sure shots just collecting dust as the viscosity was too much for the cans itself...
bigjmcconnell
Halifax, PA
Hmmm, I have Wurth bulk brake cleaner and it is as thin as water. Maybe something IS wrong with the unit. Here is the one I have:
srmofo
SW ohio
remove the tip and take the the little bronze atomizer out of it.
Its a little do dad that spins inside of the nozzle and creates the mist. With it removed, the spray will be more like a stream.
if thats still not enough for you, you can drill the hole out a little larger, but I dont recommend it unless you like refilling it every 10 seconds
Edit this, I just noticed you bought the atomizer? yeah that thing is going to spray like spraypaint. You want the model A sprayer
http://www.sureshotsprayer.com/AtomizersSprayers.html
If you get the model A, you want to remove part number 303
http://www.sureshotsprayer.com/images/Model_A_Instructions.pdf
sometoyotaguy
Southern Maine
I couldn't find anything at HF with the refillable paint can.
I have a couple of those atomizers, but I haven't tried them yet. I thought they might be handy for undercoating.
srmofo
SW ohio
theres no way you are going to get undercoating through those atomizers. Its just too thick
@bigjmmcconnell- Yeah the model A is what people refer to as a sure shot. it will blast just like an aerosol can of brake-kleen
Gary S
Bismarck, ND
I had one many years ago, and I threw it away. Using compressed air as an aerosol isn't efficient. You get only a small percentage of the volume with plain air that you get with the commercial aerosol chemicals in a pre-loaded can.
I found that after filling, it would spray fine for a few seconds, and then start to get low on pressure. It needed to be refilled with air very often, and as a result, it was impossible to put down a nice coat of paint because the pressure was varying all the time.
That has a lot to do with how full you have it for the liquid, fill it maybe half full instead if to the top, and that gives you an "air reservoir" that will last longer.
I have the same problem on my portable pressurized water tank I take camping if I overfill it. There has to be enough of an air pocket to get the job done and last.
signcrafter
I don't think these things were made for laying down a show quality coat of paint. They are meant for things like wd-40, brakecleaner, etc.
dclassical
I have been interested for a while, but not sure which is right for what I want do:
- Which model for Brake Clean?
- Which model for WD40?
Also can these models be fitted with the little red straws you find on the cans of WD40 for a precise application?
RKA
Look at their website...steel Model A will work for WD40 and BrakeCleen. They sell nozzle extensions and different spray tips as well.
http://www.sureshotsprayer.com/NozzleExtensions.html
And to the guy trying to lay down paint with these...LOL! I'll send you my address, next time you buy a nice product and decide it's better suited for a landfill, you can send it my way.
dclassical
Thank you for the link, I am not sure how I missed it! Exactly what I wanted to know.
littlebritishcar
Napa. CA
I still want to check out the Harbor Freight units for comparison but has anybody tried the Preval brand sprayers? They work well for paint because you can throw them away when you are done, so no mess. I just sprayed some epoxy primer on my MGB project with one and was pretty stoked at how well it worked. For some reason the price varies a lot depending on where you buy them but I found that Home Depot and Advance Auto Parts are the least expensive at about five dollars.
This is their website: http://www.preval.com/what-is-preval
And here is my blog if you want to see how it worked out for me. I would use a little reducer with the epoxy next time but it worked out well: www.LittleBritishCar.org
