power wagon
Re: what did you do in your garage today?
been making room for an up coming project
still moving stuff around but had to start the wood stove, getting chilly up here
Wow! Ok, where's "up here" that you need a fire - the air conditioning is on here....![]()
Yesterday I took a shower in 20 year old VW undercoating.. Today I'll be doing the same.
... or I may update to an onboard compressor and electronic air valve (anyone know a good source for those?). ...
Oh, thank you for the links. I'll pour over them to see what I can use out of them.
Right now I'm thinking of a temporary install using the parts I (my Dad) already had. But I'll likely go to at least an electricaly actuated valve eventually instead of a spring loaded manual valve and cable arrangement
Also started on a resto of old air horns my Dad had on each truck he owned when I was a kid. They've been in a box since 1990! They're nothing to look at, a bit bent (as you can see) but they're ridiculously loud. He'd announce arriving home with a short double toot each afternoon.
I'm going to scare my sister to death by surprising her with the same double toot the next time I visit her; she'll think it's Dad back from the grave.
They use an old hospital oxygen tank (oblong, about a foot long) and a manual spring loaded brass valve to actuate. He'd fill the tank at the gas station. I MAY leave it like that as a reminder, or I may update to an onboard compressor and electronic air valve (anyone know a good source for those?). Enough blah, blah. It's Rustoleum Hammertone gray:
Got tired of having to dig around three or four locations to find the screwdriver I needed so I went and bought the $20 craftsman 17-piece special, and made a little rack with a hole for each screwdriver and mounted it above the work bench, right where I need it!
